Which code should I address first? Knock Sensor or Cyl 1 missfire
Old Jul 2, 2009 | 01:15 PM
Goofball's Avatar
I have these 2 codes. Which should I fix first? I lost my job after 18 years Tuesday and money is an issue.
thanks
Old Jul 2, 2009 | 01:22 PM
HandsonMaxima.'s Avatar
go for the misfire, as i constantly hear here, KS is a ghost code, maybe the misfire is setting it off, my 2nd cyln misfire set off my KS, fixed with spark plugs, a new oil seal(to fix leak slight leak) and injector cleaner. i used them all at once to make sure i didnt have to go back to it. thats all i can think of, im sure more will come and happily give you their input.
Old Jul 2, 2009 | 01:28 PM
ThreePointO's Avatar
yea 150,000 things can set off a KS code.
Old Jul 2, 2009 | 07:02 PM
Missfire > knock sensor. If money is tight just stick a resistor in the KS harness and your good.
Old Jul 2, 2009 | 07:40 PM
Maximeltman's Avatar
missfire 4 sure.
Old Jul 2, 2009 | 08:09 PM
Snypa's Avatar
both are kinda critical.but i wud say misfire.
Old Jul 2, 2009 | 08:26 PM
erty67's Avatar
Decal Specialist
fix misfire, clear code, drive 100 miles or so, recheck for codes to see if knock sensor shows up again (it won't trigger the CEL alone)
Old Jul 3, 2009 | 07:23 AM
Goofball's Avatar
Missfire it is. Thanks guys for all your advice.
Old Jul 4, 2009 | 11:25 AM
Viperoni's Avatar
Definitely misfire.
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
