Not able to get my car to start after a tranny swap
Old Jul 3, 2009 | 10:20 AM
022580's Avatar
I just replced my 5spd transmission on my 97 maxima and when I go to start it it cranks fine but it wont start.
I triple checked all the connection and they are good.
I checked for gas and its pumping out
I checked the sparkplugs by removing one of the coil packs and put in a test plug to see if i get spark and i do not...
Whats are things I can check for ?
I also found some on NATS..... the immobilizer for nissan. Could that be the prob ? if so any steps on how to get this car going.
Any help will be appreceated.
Old Jul 3, 2009 | 11:01 AM
Enigmaz Powa's Avatar
I'm in a similar boat. You can try to ground ya starter from the 14mm bolt to the (-)battery terminal.
Also, did you ground the ignition coil when you testing for spark?
Old Jul 3, 2009 | 11:10 AM
022580's Avatar
the starter is fine...it cranks perfect.
to test the spark splug i ground the spark plug not the coil
is there a specific way to test the spark with the coilpacks ?
Old Jul 3, 2009 | 08:27 PM
Product_Of_Korea's Avatar
only 99 come with nats iirc.
Did you make sure that the ckps lines up good with the timing ring????
Old Jul 3, 2009 | 08:36 PM
Maximeltman's Avatar
ya, what he said. I just learned they have to do with spark timing
Old Jul 3, 2009 | 10:32 PM
pmohr's Avatar
No more Maximas...
As said, NATS is '99+; not relevant. Not to mention that it cuts fuel, not spark.
So, since you neglected to mention; codes?
Did you sand the mating surface between bellhousing and block? You'd be surprised what odd issues a bad ground can cause.
Gas is 'pumping out'...where? At the injectors? Because that's all that really matters. If the injectors aren't firing, who cares that you've got flow from the pump?
Did you damage the CKPS POS at all? Remove the flywheel? If so, remove the timing ring?
Have you inspected the timing ring/CKPS POS for damage?
Old Jul 4, 2009 | 08:08 AM
022580's Avatar
The fuel it coming out by the fuel filter...just before the injectors...
The house was clean before i put on the trans
Flywheel was not removed nor was the timing wheel.
im going to check the position sensor....
i have to look for code and go from there.
Old Jul 4, 2009 | 08:14 AM
022580's Avatar
i have a stupid question about codes..... i know ill prob get bashed on this.
To get codes, should i follow the procedure to get the ecu code ?
or should i purchase one of those smaller code readers ?
Old Jul 4, 2009 | 08:41 AM
pmohr's Avatar
No more Maximas...
99% of the time you'll get the same results either way.
And again, are the injectors firing?
Old Jul 4, 2009 | 04:05 PM
022580's Avatar
injectors firing... changed the cam shaft sensor cause i have a extra to test.
im getting 5 long and 5short for the code....i used the site from this forum and it says reported no problems.
can the cps on the tranny cause this ?
Old Jul 4, 2009 | 10:02 PM
I would re try reading codes and make sure thats the code your pulling
Old Jul 5, 2009 | 07:21 AM
022580's Avatar
i checked it 5 times....lol
The only thing i think it can be is the cps..... The tran i have in there now is from a 95, but the trans cps is from a 97 ...
Nissan is closed today for part so i can cross refference the part number.
would any one here know ?
Old Jul 5, 2009 | 07:49 AM
pmohr's Avatar
No more Maximas...
The CPS is nowhere near the trans, it's on the timing cover.
Do you mean the CKPS? It has nothing to do with the trans, it reads from the timing ring on the back of the flywheel. They're all identical, '95-'01.
There are a number of things that could cause a no start, just have to rule them out one by one.
Have you inspected the timing ring and CKPS POS for damage yet?
Have you made sure both CKPS' and the CPS are plugged in properly, no corrosion in the connectors, etc?
Does it sound like it wants to fire at all, or just cranks steadily with no changes?
Did you do anything else other than swap the trans?
Old Jul 5, 2009 | 11:48 AM
even if the cps is bad i think it would still start.
Like said before check timing ring and the CKPS(consult the FSM on how to test your CKPS). I would also check your grounds. I know there is a ground that goes right in front of your slave cylinder. Did you by chance unplug the sub harness that plugs in right in front of the radiator that travels down to your CKPS?
Old Jul 5, 2009 | 12:15 PM
Leo_Koneval's Avatar
Not sure if anyone said this before, but could it be that neutral position sensor type thingy that stops you from starting the car if its in D or R??
I don't remember the exact name of it but I remembered reading something about transmissions preventing a car from starting because of a specific sensor.
Old Jul 5, 2009 | 12:18 PM
pmohr's Avatar
No more Maximas...
The inhibitor would keep the engine from even cranking so as to keep it from lurching out of control. Granted that wouldn't even be an issue on an auto, I don't think the engine cranks fast enough to generate enough pressure in the trans to apply a gear, but safety first and all.
The clutch switch is just annoying, sometimes being able to bump it around with the starter is helpful.
Old Jul 10, 2009 | 06:47 AM
022580's Avatar
so now i am getting codes....
Front Left Heated O2 sensor
Intake Air Temp Sensor
Crank Position Sensor
the codes say the following items need to be checked.
CPS has been replace and still same issue, i dont see the other two cause this problem.
Any suggestions ?
Old Jul 10, 2009 | 07:41 AM
Blackwind's Avatar
you are giving us very little to go on. did you remove the old flexplate and timing ring or did you just change the trans? did you wire up the p/n switch correctly?
Old Jul 10, 2009 | 10:01 AM
022580's Avatar
All that was changed was the clutch, pressure plate and transmission. The flywheel was left as is so nothing was changed for the timing there.
What do u mean by wiring up the p/n switch correctly ? everything just clipped back in and no wiring was changed.
The motor cranks perfectly it just doesnt spark.... and i am getting those readings that are on my last post.
Old Jul 10, 2009 | 12:30 PM
QNO_A32's Avatar
check for 12v at the red wire on the connector. key on, sensor unplugged...
Old Jul 10, 2009 | 04:17 PM
Blackwind's Avatar
1st -you need to put up some pics if you have them, it will make this ordeal all the easier for us to help you with.
2nd- you DID NOT change the timing ring? am i correct on this?
3rd- NOTHING on this swap will clip together.
you did something wrong big time. get up some pics asap. what directions did you follow?
Old Jul 10, 2009 | 04:37 PM
pmohr's Avatar
No more Maximas...
Best I can tell he just replaced the trans (factory 5MT), he didn't do a 5MT swap.
Old Jul 10, 2009 | 04:59 PM
Any suggestions ?
Man sorry for nagging
But from now on refer the crankshaft postioning sensor as CKPS
And the CPS as cam shaft postioning sensor. Its very confusing to us cause this is the way we are use to hearing it.
What specific code are you throwing???? There are two CKPS's one is by the crankshaft pulley(ref) and the other one is by the flywheel(POS)(as im sure you know by now)
I would triple check sensors. Check all your fuses. Check all your gounds Especially the ones on the lower intake manifold. Then i would physically check the timing ring(remove the tranny if need be) But you could also check it by removing the CKPS(pos) and have a buddy crank the crankshaft pully and you look at the timing ring. Or you could just pull the tranny.
Old Jul 16, 2009 | 09:08 PM
022580's Avatar
to double check the timing ring is on the flywheel right ? just wanna double check cause i cant find the timing ring on the fsm.
The only thing removed and put back on are the clutch disk, clutch cover, and the transmission ontop of it.
plus the other stuff to get to the tranny.
Old Jul 18, 2009 | 10:05 AM
aNY UPDATES? Oops sorry for yellin
Old Jul 20, 2009 | 12:14 AM
CEASE225's Avatar
im having the same problem, im going to check the ckps harness
Old Jul 20, 2009 | 12:38 AM
CEASE225's Avatar
99 maxima SE-L, new 5th gen clutch kit and 2001 5 speed tranny, it was very hard to start the 1st week after installation but once it started, it ran perfecttttt but i noticed the rpms was idling at about 550 opposed to the 650-700 before work was done, I used a new ckps and it did not help, added a 4g ground wire from negative battery terminal to starter bolt and the car started 50% better then it did without the wire, but still not 100%. 2nd week the car wud just turn over and not start at all. Added a 2nd 4g ground wire from starter bolt to bottom of tranny and it did nothing. i watched my mech install the tranny, he did NOT clean or sand the bell housing bolt points. I check everthing except the ckps harness < if thats not the culprit of this problem, im 95% sure that dropping the tranny, sanding and cleaning the bolt points on tranny and motor bell housing will solve the problem
Old Jul 21, 2009 | 07:33 AM
96sleepergle's Avatar
First you should start your own thread, but to answer your question the idle speed for 5 speeds tran between 550- 625 rpms try raising it through idle control valve 650 700 is to high for 5 speeds
Old Oct 20, 2009 | 08:10 PM
CEASE225's Avatar
I never asked a question, i wrote in this thread to let 022580 know that im going thru the samething and its highly possible that the mating face on the new tranny needs to be clean!!!!
Old Oct 21, 2009 | 07:44 PM
khantalha+'s Avatar
i did a motor swap last year and had a similar problem, it was a motor from a 95 5speed, and my car was 98 auto.., car cranked, cranked, and nothing.. checked EVERYTHING...i had a few crank shaft position sensors(one on trans side) sitting around, ground the metal part of the sensor a little bit(about 1/8 of an inch) and she started right up..weird but worked..i would try doing that but get another(used)sensor so u can play with it... hope it helps..
Old Oct 22, 2009 | 11:25 AM
oVeRdOsE's Avatar
That's it! Some people get rid of the proplem by grounding the engine block and the tranny, but its an indirect solution. the CSPS need to be grounded on the engine block and the tranny too!!! Even if you take a wire from the tranny to the battery, IT IS NOT enough.
So before trying everything, grind the CSPS and the tranny screws/ metal part to get a better contact tranny/engine block.
it may help
good luck
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Supragte
Aug 12, 2015 10:00 PM
Maxboy23
Aug 11, 2015 11:59 AM
Blackwind
Aug 5, 2015 06:35 PM
