maxima woes......
Old Jul 4, 2009 | 11:13 AM
Nycist's Avatar
maxima woes......
so the car semi-overheated today.
Funny thing though. I saw the temp gauge jump a lil higher than usual, so i turned on the heat and rolled down the windows. My house was only a few blocks away. No heat came out. It was as cold as a/c. I checked my coolant when i got to the fort. There was hardly any in there. Oh well. Then i left to head to my parent house.
So im thinking.......leak in cooling system somewhere. Unless i get back home and find milky oil....
Old Jul 4, 2009 | 12:00 PM
pmohr's Avatar
No more Maximas...
Well have you checked for a leak yet? Looked for anything, or did you post here first?
Pressure test the system, look for leaks.
Old Jul 4, 2009 | 12:02 PM
maxfever1987's Avatar
put coolant in there asap, then like stated above check to see where your leaking it from, do you see any leaks once you drive off where you were parked? ir do you see white smoke coming from your muffler?
Old Jul 4, 2009 | 05:50 PM
beez5spdmax's Avatar
Have u ever changed ur radatior ? Could be that that's how mine started acting up same way . Just run a pressure test
Old Jul 4, 2009 | 07:13 PM
Nycist's Avatar
i posted here first. i had to grill all day over at the parents bbq. i figured you guys could help me brainstorm while i was there..
i saw no obvious leaks when i pulled off where i parked.
i saw no white smoke coming from the exhaust.
ive never changed the radiator.
the pressure test will be the first thing done in the morning.
Old Jul 4, 2009 | 07:15 PM
pmohr's Avatar
No more Maximas...
Originally Posted by Nycist
i posted here first. i figured you guys could help me brainstorm. i know i dont mind doing it for others.
If it's the original radiator, that could very well be it, they tend to develop cracks over time. Look at the bottom of the fill neck:
96nismoSE's Avatar
dont get your panties in a bunch.
Old Aug 1, 2009 | 12:10 PM
marktab's Avatar
Changing the radiator is not that hard, and may be necessary -- look inside to see the condition, and also look for cracks where the pipes connect
Old Aug 1, 2009 | 01:15 PM
max ride 41's Avatar
common sense goes a long way. you should pressure test, flush and refill after you determine whats going on, ie, leak in rad, leaky hose, etc. DO NOT WAIT, do it immediatley!!!!
Old Aug 2, 2009 | 02:26 PM
MaxPR0908's Avatar
That is right, must be the radiator or any hose, like they said refill the system and get a pressure test to find out any leaks.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
