My Max has some trouble starting.
Old Jul 6, 2009 | 03:14 PM
96WhiteMaxima's Avatar
Maybe I'm just paranoid, but my car has trouble starting sometimes at random. Yesterday I was at Walmart and I put the key in it and it tried to start then it made a sound like a DJ slowing down a song all of a sudden and then going back to normal, it did that 3 times before the car started (probably not the best analogy but its the best I can come up with), and normally the car doesn't start up right away like its supposed to, it cranks for about 4.5 seconds before the engine actually starts. So what do you guys think? Alternator or starter motor, maybe both?
Old Jul 6, 2009 | 04:34 PM
aackshun's Avatar
I'm not the brightest when it comes to cars... But why not the battery?
You can have your alternator and battery checked out at autozone for free anyways or do it yourself if you have a voltmeter.
Old Jul 6, 2009 | 05:13 PM
Simple reason? I like to over complicate things but thanks, I'll go ahead and get those checked out.
Old Jul 6, 2009 | 05:52 PM
maximamazing's Avatar
I also have a small problem with starting my car, but I think it is just electrical.
Almost everytime I go to start it it does nothing. I have to release the clutch and depress it again and turn the key hard all the way to "start"
and it's a little rough starting.
It's no big deal, just kind of annoying... but does anyone have an idea what it could be?
Old Jul 6, 2009 | 05:53 PM
whiteSE's Avatar
i had that problem. it was my ground was rusted
Old Jul 6, 2009 | 06:11 PM
You mean the ground to the starter? I'm not all that knowledgeable about these things haha..
Old Jul 6, 2009 | 06:12 PM
whiteSE's Avatar
i was awsering the OP. what happened on mine is that the ground that connects to the chassis got rusted
Old Jul 6, 2009 | 06:18 PM
Ahh had a feeling.... my bad.
Old Jul 6, 2009 | 06:25 PM
pmohr's Avatar
No more Maximas...
If you jiggle the key around a little, does it help at all?
Have you tried bypassing the clutch switch to rule that out?
Old Jul 6, 2009 | 06:26 PM
pmohr's Avatar
No more Maximas...
Could be a bad starter, bad ground to the trans, bad connection, etc.
Did you do anything, have anything done, or did anything happen to the car prior to this occurring?
Old Jul 6, 2009 | 06:28 PM
Product_Of_Korea's Avatar
Any codes???
Old Jul 6, 2009 | 06:39 PM
Yes actually it seems to help a little, but not on the first try.
I hadn't thought of bypassing anything. How would you go about doing it?
Old Jul 6, 2009 | 06:40 PM
pmohr's Avatar
No more Maximas...
Unplug it and stick a paperclip in the two pins of the harness connector.
Old Jul 6, 2009 | 06:47 PM
Ahh thanks. And will this allow me to start the car without depressing the clutch?
Old Jul 6, 2009 | 06:48 PM
pmohr's Avatar
No more Maximas...
Ahh thanks. And will this will allow me to start the car without depressing the clutch?
Correct.
If you plan to make the mod permanent, I've always taken back some of the sheathing on the clutch switch harness, stripped some insulation from both wires, twisted them together, taped it all up, put the sheath back on, and plug it back in. Looks factory, disables the switch.
Old Jul 6, 2009 | 06:51 PM
Interesting, that thought would have never crossed my mind.
I will surely give it a try.
Thanks!
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
zmcneely13
Sep 26, 2015 02:26 PM
