Weird Interior Door Light Problem
Old Jul 8, 2009 | 05:04 PM
wirelessdude04's Avatar
So my passenger side work's but the bulb is very dim, the driver side doesnt work at all??? What gives any info on this? Check the fuses, the wire's switched bulbs, nothing
Old Jul 8, 2009 | 08:27 PM
maxfever1987's Avatar
i have the same issue, but its intermittent. i gave up on it at this point
Old Jul 8, 2009 | 08:50 PM
Cobraindanight's Avatar
well i say start with a test light and find out which wire has the 12v which i think has power at all times and i belive it is a red wire the other wire is a ground which comes from the window switch or known to nissan as a LCU it controls the ground when you open the door, supply ground to the ground wire of the light if it comes on you have a bad window switch if you do not have power to the light then you have another problem and PMOHR can tell you better then i can, its late and im sorry to say im tired of writting, ive had this happen to me twice
good luck
Old Jul 8, 2009 | 08:53 PM
EnervinE's Avatar
i has college
http://forums.maxima.org/4th-generat...or-lights.html
Lakersallday24
Nov 7, 2024 07:31 PM
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
