Oxygen Sensor question (4 wire)
Old Jul 16, 2009 | 09:03 PM
mbhang's Avatar
I once bought a brand new set of O2 sensors for a 97 Mercury Sable (that I had to shortly donate, as it was failing emissions, low pressure on 1 cylinder - I just hated that car - so I donated it).
But the sensors had hardly seen a few hundred miles, so I removed them and put in the old O2 sensors.
My Maxima (CA spec) is getting in the 120 K mile range. I wonder if I can use the 4 wire (after splicing with Maxima connector) as replacement.
I was hoping the Universal sensor for the 2 models were same for 4 wire, but they are not. For example - it is Bosch 15730 for the Sable, and Bosch Part Number 15727 for the Nissan Maxima. I wonder if the actual sensors are identical.
Thanks,
Manish
Old Jul 16, 2009 | 09:22 PM
mbhang's Avatar
I like to add -
I think the only difference may well be the color of the wires on the sensor.
Wonder if anybody has any insight into this.
Thanks,
Manish
Old Jul 16, 2009 | 09:35 PM
pmohr's Avatar
No more Maximas...
They do appear to be the same, looking at the product info.
Test the O2s per the FSM, see what you come up with. You're going to have to figure out what wire goes where, though.
Between that and a visual inspection, you should be able to determine whether or not they will work.
kjlouis
Nov 24, 2018 06:09 AM
sake1bs
Sep 19, 2015 09:32 PM
Slamrod
Sep 3, 2015 07:38 PM
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 3, 2015 07:53 PM
