brake pad help
Old Jul 27, 2009 | 11:43 PM
Turbo515's Avatar
brake pad help
Hey. i have a 96 maxima and im about to change the brake pads and was going to use raybestos advanced tech pads(used to be quiet stops i think). when i went to buy the pads the person at lordco said that if i use them with the stock rotors that it would warp them and i should use the pro grade ones. i put the pro grade ones on another car that i had and it sqeaked a lot so i figured i would try the A/T ones this time. my question is if i use the raybestos A/T pads should i change the rotors first or will the stock ones work fine? would the pro grade ones work fine if i use some anti squeak on them? finally lordco wants i think $130 for the front and $110 ($CAN funds) for the rears. is there anyplace that i can get them cheaper in vancouver or online or is that the going rate?
Thanks for the help.
Old Jul 27, 2009 | 11:59 PM
RB240's Avatar
I think that as long as you get your current rotors resurfaced you can use whatever pads you want along with some of that anti squeek grease and you should be fine. no reason to buy new rotors when your old ones just need to be freshened up a bit, around here a machine shop charges like 10-15bucks a rotor not bad compared to a 100 dollar plus one
Old Jul 28, 2009 | 08:14 AM
Juscruzn's Avatar
Take the time to seat the pads. Do a search on it. It involves stopping the car from different speeds....
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
