Picked up a Oil catch can @ Home Depot
Old Aug 3, 2009 | 09:53 PM
shadyonedeath's Avatar
Its a husky, looks like they changed design apart from the earlier catch can HOW-TO threads. I saw one at Lowes but the nipple on the bottom was brass and looked weird. It was barbed and let air out unless that nipple was pulled down. I didnt buy it because i thought it would be leaking everywhere unless i found a way to keep the barb nipple pulled down all the time. (pulling it down seemed to close the air flow)
check out this nice warning label... hope it lasts.
How-To threads:
http://forums.maxima.org/4th-generat...-can-pics.html
http://forums.maxima.org/5th-generat...catch-can.html
Old Aug 3, 2009 | 10:27 PM
G4nismo's Avatar
nice. i only see 1 nipple fitting though. don't you need another one for the other side?
how much was all that? i need to do this pretty soon...
Old Aug 3, 2009 | 11:05 PM
Im going to buy a 90* degree fitting for the other side. Making a mount out of aluminum sheet and i want to use as little tubing as possible. the straight side will be for the PCV valve and the elbow fitting will be for the top vacuum nipple on the Upper Manifold. Maybe i should get 2 elbow fittings..hmmm well see. If they didn't cost 5$ each i'd would be easy. lol
filter is 12$ and the straight fitting, which i found in the same area of Home depot as the filter, was like 2.50.
Old Aug 4, 2009 | 04:57 AM
S1cTech's Avatar
So what is this for? Looks like it is for an air compressor?
Old Aug 4, 2009 | 05:37 AM
mmg23max's Avatar
did you read this
How-To threads:
http://forums.maxima.org/5th-generat...catch-can.html[/quote]
Old Aug 4, 2009 | 09:25 AM
G4nismo's Avatar
did you not read the title and what the OP posted on the bottom of his post?
Old Aug 4, 2009 | 09:49 AM
wirelessdude04's Avatar
one of the best mods ive done yet
Old Aug 4, 2009 | 10:06 AM
MOHFpro90's Avatar
I need to buy 2....
One for my air compressor and one for my max...
Mar 12, 2020 12:06 AM
kjlouis
Oct 3, 2015 05:29 AM
bbsitum
Sep 11, 2015 04:55 PM
pjgreek
Sep 9, 2015 09:30 PM
ag90fox
Sep 9, 2015 12:22 PM
