No Power to 96 Headunits
Old Aug 7, 2009 | 10:06 PM
maXspeed96se's Avatar
when i bought my car the headunit didnt work. he said it worked then he went out one day and it just stopped working. while i was driving it sometimes it would just cut in and out randomly. so i got an Alpine headunit from a friend and got it wired up and cut the car on.......NOTHING!! so we thought it could have been a bad headunit so we tried it in a friends wife's accord. it cut right on. i went yesterday to a Nissan performance shop and they happen to have 3 Bose headunits. i tried all 3 of them and none of them turned on. the only i could hear is the antenna going up and down and when i pressed eject it made the whinning noise that it should. any ideas what could be wrong??
Old Aug 7, 2009 | 10:32 PM
kzoosho's Avatar
check fuses?
Old Aug 8, 2009 | 08:18 AM
NisMoN00B's Avatar
+Cru OG
Put some Sushi on it .. or in it.
Old Aug 8, 2009 | 03:39 PM
Originally Posted by kzoosho
check fuses?
all the fuses are good
Old Aug 8, 2009 | 03:40 PM
Old Aug 8, 2009 | 05:26 PM
pmohr's Avatar
No more Maximas...
Well have you checked to make sure it's getting both constant and switched B+ at the appropriate pins of the connector(s)? Good ground?
Old Aug 9, 2009 | 10:31 PM
rechecked everything and its all good.
Old Aug 10, 2009 | 09:30 AM
kzoosho's Avatar
So you are getting power and ground but wont power on? Makes no sense sir.
Old Aug 10, 2009 | 10:11 AM
pmohr's Avatar
No more Maximas...
Indeed. If it's getting power and ground, and has all been hooked up correctly, then there's something very amiss.
So you did check for both constant AND switched B+ as I said, correct? There are two power feeds to the radio, the constant won't make it work. Also, you checked to make sure the ground is good? You were hardly descriptive in your methods.
Old Aug 10, 2009 | 10:22 AM
kzoosho's Avatar
I dont know if he realizes thats all he needs for electrical items. If you have bot batt+ and batt switched and ground you can power anything in the car.
Old Aug 10, 2009 | 03:00 PM
its getting power but not cutting on
even when i plugged everything into the other bose headunits, they still wouldnt come on
grounded it, plugged in both harnesses and the black antenna.....nothing, after i checked it
Old Aug 10, 2009 | 03:02 PM
pmohr's Avatar
No more Maximas...
Okay, obviously this is going to be a trying dialog.
Have you or have you not checked for BOTH constant and switched B+?
We can't help if you completely neglect to answer our questions. And what did you ground? Are you assuming that it'll ground through the case, or did you run a new ground wire to the pre-existing ground wire?
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
