Benefits of Underdrive Pulley?????
Old Nov 29, 2001 | 01:42 PM
  #41
Sprint's Avatar
Originally posted by ejj5875
So now that there are perfectly legit numbers on the table that's all you can say? A waste?
What do you think account for his 6hp gain? Magic?
my point is.. i am not going to keep arguing with you guys because you have your points... i have mine.. point is.. its a waste of $150.. keep believing what you want..
Old Nov 29, 2001 | 01:55 PM
  #42
PhatGuy
Originally posted by SprintMax
muhahah ...
8 - 10 at the wheels... muhahhaha
what kind of dyno is that? canadian dyno with metric mesurements.. muhahhahaha.. you talking Horsepower? or pony power?
Hmmm Canadian dyno?? Well Canada as well as 90%+ of the countries on the planet earth use the metric system. USA is the only country I know of personally that still uses the imperial system.
Old Nov 29, 2001 | 02:01 PM
  #43
Sonic's Avatar
And we get away with it too. Why? USA RULES!!!
  #44
RastaManMax's Avatar
Power to da Canadians
Old Nov 29, 2001 | 02:07 PM
  #45
Sprint's Avatar
i know that.. i grew up in Jamaica for 16 years...
Old Nov 29, 2001 | 02:08 PM
  #46
Sonic's Avatar
Running 2 dynos back to back got me a number differnce of 4 HP with NOTHING done to the car in between the runs. How many times did you dyno? Once?
Old Nov 29, 2001 | 06:12 PM
  #47
Dave B's Avatar
Not DAVEB the parts guy
Originally posted by medicsonic
So we have one person that dynoed it and got a 6 HP difference, but he hasn't been to the track IN THE SAME CONDITIONS to see if he got 'any faster'. Then we have someone who got .06 faster(), but again hasn't run UNDER THE SAME CONDITIONS, but hasn't dynoed the car. Until you have both dynoed AND run under the same conditions, your emperical data will stay unproven.
Alright, the NHRA has said that for every 10 degrees in temp over 60 degrees, you loose about 2% of your power. Ideal racing temps are between 50-60 degrees. With all that said, I've run much higher trap speeds WITH the UDP in MUCH warmer temps than I ran my best. I'm only 0.02 off my best and I was exceeding my best trap speeds by over 1mph. Without the UDP I NEVER got any better than 94.01mph. With the UDP, I've run almost all 94-95mph+ trap speeds (unless I had a bad launch or shift). That right there says my car is stronger especially when I'm running in warmer weather (70s+) vs my best in cooler weather (40s). By your post, it appeats you're suggesting that I will probably run slower in cooler weather. What kind of racer are you? Benchracer? Most gearheads know that trap speed is a clear indicator of how fast the car can really be. I will be dynoing next Saturday and I plan on putting this debate COMPLETELY to rest.
Who here thinks Sprint and Med will be in line to buy UDPs once they ride in a Max with one installed, more less get pulled on by one
Dave
Old Nov 29, 2001 | 10:54 PM
  #48
BriGuyMax's Avatar
Dave
ooo..oooo....ME!!! :
Old Nov 29, 2001 | 11:15 PM
  #49
Nealoc187's Avatar
SLOW
I'm buying one, that's how convinced I am. I've seen a dyno and trap speeds to back it up now, I don't know what else can be said to convince someone.
Old Nov 30, 2001 | 02:56 AM
  #50
Sprint's Avatar
I will never buy a UDP.. NEVER...
besides.. i don't see too many cars on the org that can pull me so i am not worried about it..
Old Nov 30, 2001 | 04:33 AM
  #51
Sonic's Avatar
Dave
I have PULLED on TWO that have them installed with the same mods. And yes, I'm a bench racer, I have only run my car in the 1/4 30 times for far. Call me a newbie.
Old Nov 30, 2001 | 05:39 AM
  #52
Anachronism's Avatar
The only downside to the UDP with a 5 speed is the fact that it is harder to start smoothly off the line and on the 1-2 shift.
Dave
Anyone else with an UDP notice this? I am considering this Mod in the future and you guys almost have my convinced it's worth it, but I do not want to do anything that hurts the smoothness and drivability of my 'family car'.
Edit - BTW I have a 5 speed. (forgot the sigs where still down)
Old Nov 30, 2001 | 06:06 AM
  #53
ejj's Avatar
ejj
At first yes. But its something that you can quickly adapt to. Just takes getting used to, as I imagine something like a lightened flywheel would.
Not a big deal. Oh, and I'd imagine that it would only apply to 5-speeds.
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
