My turn signals, burning fuses
Old Aug 10, 2009 | 06:45 PM
manny097's Avatar
About a week ago going i notice that wen i put my left signal on it burn the fuse
wen put on right side it works, my hazards work, when setting the lock on my key fob they blink. so i bought a turn signal switch from a fellow member thinking that would solve the problem but wrong
Any advise on this? i hope its not a major electrical problem
Old Aug 10, 2009 | 07:02 PM
pmohr's Avatar
No more Maximas...
Which fuse? 'Turn' or 'Hazard L'?
Hazards will flash all 4? If you unplug both of the left side bulbs, does it still pop the fuse? If not, then try them one at a time.
If so, then...
First thing I would check for is any damage to the connectors for both the hazard switch and the turn signal switch, also testing the switches themselves. Next would be continuity testing on the wiring harness, checking grounds, etc.
Really there's only a very small portion of wiring that bypasses the hazard switch when you use the turn signal switch, and it should pop the fuse when you use the hazards or locking/unlocking the car with the keyless entry remote.
Old Aug 11, 2009 | 08:03 PM
97BlkMaximus's Avatar
Ugh.
I will never be useful on this side with a Maxima god like pmohr around...
That means there's only one thing I can do...
Haha. But on the real, you MUST be a Nissan Tech huh?
Nice answer!
Old Aug 11, 2009 | 09:42 PM
manny097's Avatar
If so, then...
Yeah it fix the problem i unplug both left bulbs didn't pop the fuse, check the sockets, they where good. The front bulb was the problem, even though it still work i guess it was old
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
LtLeary
Sep 14, 2015 12:33 PM
minsbang
Sep 11, 2015 08:48 PM
