Funny noises coming from wheel
Old Nov 27, 2001 | 08:57 PM
jules's Avatar
I just started hearing this funny squeaky noise and something kinda clanking (like a screw or metal object being rolled on metal)coming from my front left tire area. Whats weird about the noises is that they only occur when im going like 5mph and under, after that i hear nothing. This definitely wasnt always like this and i just heard the noise tonight so i cant really see under there.. I will check it out tomorrow but am wondering what i should look for? Any ideas on what it might be?
Thanks in advance, Jules
Old Nov 27, 2001 | 11:26 PM
paul-e's Avatar
Re: Funny noises coming from wheel
i have been having the same problem on my front left wheel and its driving my insaen...please someone help....its kinda squeaky
Old Nov 29, 2001 | 03:01 AM
nizmo95's Avatar
its sounds like you struts need to be replaced, had the same problem on mine.
Old Nov 29, 2001 | 12:40 PM
jules's Avatar
I want to end up with the kyb agk struts but im in the process of saving up some money right now, would it be so bad to ride around on the current ones for a little while? (if that is the problem)
Old Dec 2, 2001 | 03:41 PM
nizmo95's Avatar
It shouldn't be a big problem as long as you can stand the sound, it nearly drove me insane!
Old Dec 2, 2001 | 06:33 PM
Weasel's Avatar
Please describe more... does the sound happen in any direction, just while turning, when hitting bumps?
Old Dec 2, 2001 | 07:25 PM
jules's Avatar
Re: Re: Funny noises coming from wheel
Actually it happens when im going str8 and very slow, when i turn hard the noise goes away. I think the noise continues as i accelerate but i cant hear it with my head hanging out the window due to the engine and wind. The clanky noise vanished which makes me think a screw or something came loose and fell off?
Jules
Old Dec 2, 2001 | 09:13 PM
Weasel's Avatar
Re: Re: Re: Funny noises coming from wheel
Jules
I doubt it's your CV joint then, that would be the opposite of this situation as far as I know. Definitely sounds like something could be loose and rattling around.
Old Dec 2, 2001 | 09:32 PM
99maxi's Avatar
i have a similar problem with the driver side front wheel. when i am at stop and then accelerate i hear a small clank, like something hitting metal. it is driving me nuts too. but i have not have time to look around for loose stuff in the enigne bay.
Old Dec 2, 2001 | 09:33 PM
tifosiv122's Avatar
I might not understand, but when your brake pads get too low, there is metal that hits the rotor, telling you to chage the pads. If they are very low that might be your problem.
Good luck,
Erik
Old Dec 3, 2001 | 07:21 AM
MaximaPower's Avatar
i have the same noise...can't figure
out wat it is...but i'm sure it's not
the brake pads...please post if u find out
wat it is
Old Dec 3, 2001 | 11:03 AM
dashingMax's Avatar
Good luck,
Erik
This is NOT from the brakes. I have the same problem. Driver side Front wheel. It squeaks at random. I can stick my head out the window at slow speeds and hear a mild but constant squeel.
I can hear the same noise at higher speeds when I have my window down and drive next to the cement divider. It is drving me NUTS for I cannot figure out why. I want to fix it but don;t know WHAT it is that I need to fix!!!
Old Dec 3, 2001 | 12:42 PM
Wizeguy's Avatar
I had the same noise, slight clanking when going slow. What it end up being was a rock in the disk brake. I could see it in the vents. Once the car got up to speed the rock would get pushed to the inside of the disk and stop moving. I was able to get it out with a screw driver. Take a look in there.
Old Dec 3, 2001 | 01:30 PM
dashingMax's Avatar
I am guessing something stuck in the brake disk also. I'll take apart the brakes (pads and rotors), clean the hell out of it using some brake cleaner and put everything back together. I just hope that works.
I just hope it is nothing serious like the wheel bearing. Thx for your input. I will post my findings on this thread...
Old Dec 3, 2001 | 02:41 PM
jules's Avatar
That would explain the clanking noise but what the **** is the squeaking, that noise is starting to really **** me off.
Thanks, Jules
Old Dec 3, 2001 | 08:58 PM
99maxi's Avatar
i looked around for the source of the clank sound and could not find anything loose. i did notice that if i put my foot on the brake and give the car gas i will hear the sound.. anyone able to tell me what the probelm is?
Old Jan 14, 2002 | 09:46 PM
ßaller's Avatar
I just found this post thru a fellow org member. I hear clanking noise when driving and turning left, when in motion and turning right, I hear no noise. i have my windows rolled down and the clanking sounds come from the front driver side tire area. I just had my cv boot replaced in that area, and I doubt it the cv boot. I also notice that I had to add some brake fluid for the second time in three weeks.
Old Jan 14, 2002 | 11:19 PM
95emeraldgxe's Avatar
what size are your rims???? - are they rubbing?
Old Jan 14, 2002 | 11:26 PM
ßaller's Avatar
My 18x7.5 rims in the sig pics are fine. I have the stock 15 inch GLE Rims on right now for New England Winter.
Hondarydr
Dec 30, 2024 06:15 PM
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
Starrider
Sep 17, 2015 07:26 AM
homeyclaus
Sep 3, 2015 06:15 PM
