Are 99 EGR's diff than 95-98?
Old Aug 13, 2009 | 01:19 AM
shadyonedeath's Avatar
I saw this post by a reputable member but held back on "bumping" it because people get prissy if the thread is old and revived.
http://forums.maxima.org/4th-generat...ming-soon.html
Post #12
He says its similar to 5th gens?
Old Aug 13, 2009 | 02:32 AM
whlimi's Avatar
Yes, they are different. 99s use a stepper motor to control EGR flow.
Old Aug 13, 2009 | 02:34 AM
whats does that mean in terms of...remove-ability? Whats a stepper motor?
thanks
edit: I have 99 Fed-spec btw.
Old Aug 13, 2009 | 05:10 AM
whlimi's Avatar
Instead of using vacuum and a diaphragm to control flow, it's electronically controlled via a stepper motor which is just a motor that has the ability to move in small increments (steps) which offers much more precise EGR flow.
It can be removed but you will have an EGR code and your car will go into fail safe mode. I have experienced this and it's in the 99 FSM, and you will not be able to rev past 3000 rpm.
If you want to remove the EGR system, just have the section with the motor zip tied somewhere in the engine bay and connect the harness and you wont have any problems.
Old Aug 13, 2009 | 05:49 PM
pmohr's Avatar
No more Maximas...
Indeed, that's the best way.
Think of it sort of like the main IACV motor, adjusts in and out to regulate flow.
shilov
Feb 19, 2024 09:40 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
maxima297
Sep 24, 2015 10:31 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 19, 2015 01:07 AM
