Foggy 4th Gen Headlights...Best Way to clean?
Old Aug 16, 2009 | 05:48 PM
Q8BallMAXIMA's Avatar
Has anyone ran into this issue? How have you resolved it? I have tried using a plastic polish, but it seems after the winter up here in WI they get all crappy looking and "foggy".
PLEASE HELP
Thanks in advance.
Old Aug 16, 2009 | 06:10 PM
anomaly117's Avatar
search is your friend. wetsanding is the best way to fix this. i used turtle wax's headlight restoration kit from autozone. worked pretty well
it is a 4.5 with plastic lenses im assuming, right?
Old Aug 16, 2009 | 06:25 PM
My car is a 98 SE with plastic lens, I am not sure about the 4.5. How often have you had to do this...once...twice...or more?
Old Aug 16, 2009 | 06:34 PM
maxfever1987's Avatar
4.5 generation means 97-99 maximas.
Old Aug 16, 2009 | 06:39 PM
anomaly117's Avatar
ty maxfever
you may need to repeat the process to keep up with the lights, but not as often as you need to keep using polish. i noticed polish only lasted about a couple weeks for me. the restore kit works better and effects last longer.
Old Aug 16, 2009 | 06:48 PM
nalc's Avatar
Or it means any 4th gen with a VQ35, depending on who you talk to. In this context, the important thing to note is that the 97-99 have freeform reflectors with a clear polycarbonate lens, which hazes over due to UV exposure. The 95-96 have parabolic reflectors with a fluted glass lens, which does not haze. I never understood why people don't put the old glass headlights on the newer ones. Instead, it's more common to put the newer, inferior headlights on the 95-96. IDK why, though.
I use Meguiar's PlastX on mine. Regular application should remove some hazing, and prevent further hazing. However, it doesn't really clean up the pitting. A lot of people wetsand. Use at least 3000 grit if you're going down that path, and make sure to apply PlastX or another plastic protectant after wetsanding. I've never tried a "kit", but I've heard lots of favorable reviews. Wetsanding is a mixed bag, because once you start wetsanding, the UV protectant is gone, so you need to keep applying plastic polish, and periodically wetsanding again - it's not a "set it and forget it" kind of a thing.
Old Aug 16, 2009 | 07:41 PM
I have the Meguiar's PlastX, but I am really worried about the wetsanding thing. Is there a UV protectant replacement for the lens after wetsanding? Would a normal clearcoat work or will that eat the plastic lens? I know I am being picky and stuff, but it's my ride and I like it looking nice. I will continue to do some research on the UV protect thing, but I am not sure if there is anything is out on the market.
If anyone finds anything or knows of a plastic UV protectant, please add it to the thread for anyone who is researching this.
Thanks for all the help so far.
Old Aug 16, 2009 | 08:03 PM
anomaly117's Avatar
the classification of generations is determined by body style and year released. nothing else.
Old Aug 16, 2009 | 08:12 PM
nalc's Avatar
No. a 4th gen is any 95-99 with a VQ30. A 4.5 gen is any 95-99 with a VQ35. All the VQ35 swapped 4th gens call their cars "4.5 gens", whether it's a 95-96 or a 97-99.
Old Aug 16, 2009 | 08:15 PM
Guys,guys please i don't need to know about the gen thing...is there anything you know about how to clean plastic lens. Again I have a 98 SE MT (with a VQ30DE) with plastic headlight lens.
Please keep it about the subject........thanks.
Old Aug 16, 2009 | 08:26 PM
shadyonedeath's Avatar
1. Go to detailing section
2. Skim through stickies
3. profit.
Old Aug 16, 2009 | 08:38 PM
unikmax98's Avatar
i used Brasso to clean mine and it came out really clean and clear
Old Aug 16, 2009 | 09:14 PM
deezo's Avatar
3M has a kit which Autozone sells. It's the BEST method I've seen and it works. I have the Meguires Plastix also and it doesn't compare to the #m kit. My headlights look close to new again thanks to the 3M solution.
Old Aug 16, 2009 | 10:03 PM
MOHFpro90's Avatar
Brasso works well.
Old Aug 16, 2009 | 10:52 PM
DennisMik's Avatar
here are links to 2 threads about cleaning headlights:
http://forums.maxima.org/detailing/5...ning-pics.html
http://forums.maxima.org/detailing/3...es-2-08mb.html
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
MaxStock
Aug 12, 2015 08:33 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
