What on earth is this on my hub area?
Old Aug 17, 2009 | 12:57 PM
NevadaJack_9's Avatar
I took off my caliper, pads, bracket, and rotor and this is what I found. What is it? Should it be there?
Old Aug 17, 2009 | 01:09 PM
Kevlo911's Avatar
Kevlo for President
Looks like iron shavings? Should not be there
Old Aug 17, 2009 | 01:10 PM
Safe to brush it away?
Old Aug 17, 2009 | 01:11 PM
Kevlo911's Avatar
Kevlo for President
Should be. I assume you don't have abs?
Old Aug 17, 2009 | 01:22 PM
njmaxseltd's Avatar
That's the ABS ring on the d/s.
The metal dust could be a sign of a pending problem. Check your wheel bearings, those shavings could be a bearing self destrucing. Any strange noises coming from the front wheels? Grinding, dry sort of noises?
Old Aug 17, 2009 | 05:49 PM
Well there was a loud grinding, so I replaced the Rotors, pads, torque member, and all the hardware. I took it for a spin and the grinding was still there. So I rechecked all the bolts and two were loose. Retightened, noise gone. And, I have ABS. The ABS light has been on since the day I bought the car. I need to get that checked out now. How do I go about getting that checked?
Old Aug 17, 2009 | 05:50 PM
And the metal shavings were magnetized??? Very weird
Old Aug 17, 2009 | 05:55 PM
Kevlo911's Avatar
Kevlo for President
Check the sensor. IIRC the sensor is a magnetic sensor
Old Aug 17, 2009 | 06:46 PM
DAVE Sz's Avatar
Hooooooonda.....
yes the sensor is magnetic. If the shavings were magnetic they would be stuck to everything not just the ABS sensor. Clean them off and maybe that will fix the ABS light, not likely...
Old Aug 17, 2009 | 06:59 PM
pmohr's Avatar
No more Maximas...
Well the first step is to pull the codes. Have you done that yet? If not, search and you'll find the procedure.
Old Aug 17, 2009 | 07:02 PM
nsnrider's Avatar
looks like shavings from a rotor when you drive on worn out pads for too long, clean off the sensor.
Old Aug 17, 2009 | 09:14 PM
DAVE Sz's Avatar
Hooooooonda.....
Maybe I should do this as well. Make sure it's only the cracked and molested sensor that's bad...
Old Aug 18, 2009 | 03:18 AM
pmohr's Avatar
No more Maximas...
Originally Posted by DAVE Sz
What codes? He said his abs light is on not his CEL...
And the light is there to indicate something, it doesn't just come on without an explanation.
Just because there's no CEL doesn't mean the term isn't relevant, as one can pull codes from the TCM as well without the CEL being lit.
Old Aug 18, 2009 | 09:02 AM
DAVE Sz's Avatar
Hooooooonda.....
I looked at the fsm and found that the ABS light is used for diagnosis just like the CEL or the AT light. Now I just want to know how 6hrs after I edited my post, you still quoted the pre edit version?
Old Aug 18, 2009 | 09:05 AM
GCTDrizzle's Avatar
yea, i had this on my car after i drove a bad caliper and destroyed the rotor, it's just pieces of metal that get attracted to that because of magnetism. just brush it off and make sure your caliper isn't seized.
Old Aug 18, 2009 | 10:51 AM
Yeh, the ABS light is still on. Didn't think that would fix it. I'm going to check it out prob Thursday. I'll let everyone know.
doctorpullit
Mar 29, 2016 11:08 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
Andy29
Sep 29, 2015 05:32 AM
