Rear Passenger Caliper Leaking
Old Aug 17, 2009 | 11:14 PM
Dexter's Avatar
Has anyone else had this problem? Did you have to get a new one or was there an alternative solution available?
Old Aug 18, 2009 | 03:40 AM
pmohr's Avatar
No more Maximas...
Well, where exactly is it leaking from? The banjo bolt? The piston seal?
A solution is completely dependent on what the problem is.
Old Aug 18, 2009 | 04:54 AM
nafddur's Avatar
I had a leak from a remanufactured replacement caliper once. I could see that a rubber seal (I think where the E-brake assembly attached to the caliper) wasn't seated properly, so I just took it back and exchanged it for another caliper.
Old Aug 18, 2009 | 08:43 AM
GCTDrizzle's Avatar
where's it leaking? if it's not from the line itself, it'd probably be easier and save you some time and confusion to just replace the caliper. it's easy and cheap enough.
Old Aug 18, 2009 | 01:55 PM
borrowman's Avatar
rebuilt calipers are the way I went. very easy DIY job.
Old Aug 20, 2009 | 12:36 AM
Dexter's Avatar
re:
I think the leak is coming from the caliper itself, the lines are clean but the caliper has this mucky buildup all over it
Old Aug 21, 2009 | 10:08 AM
nafddur's Avatar
As everyone else here has said, just get another caliper and put it on. Almost any auto parts store has rebuilt ones from $50-100, and they only take about 1/2 hr to change. Simple fix.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
george__
Aug 18, 2015 07:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
