What's wrong with my car?
Old Aug 28, 2009 | 11:02 PM
paulsfds's Avatar
I have a 99 SE Maxima (97k miles) and I always fill up my gas using premium. This might just be a coincidence, but the last 2 times that I used regular/plus, my CEL came on a few days later and I noticed that when I pressed on the gas, the acceleration was not smooth. The car felt very shakey in the low rpms but got a little better in the higher rpms. It also felt like there was a lot of hesitation during the acceleration. It almost felt as if the clutch was slipping badly or something was wrong with the air intake.
I was unable to get the CEL code because after I filled up my tank with premium again, the light went away after a few days. The first time this happened was a couple months ago when I filled up with regular. I had the same issues and the CEL came on, but a a week later I filled up with premium and a few days later the light went away and everything was fine.
My car seems to be fine now, the acceleration is smooth and I don't notice any hesitation. I don't think it has to do with the type of gas I used and probably was just a coincidence. Any ideas? I'm confused
Thanks in advance!
Old Aug 28, 2009 | 11:05 PM
rex3001's Avatar
the lower octane was probably setting off your knock sensor... stick to 89 octane or higher. i believe the manual calls for at least 91??
i always get premium just to be safe.
Old Aug 29, 2009 | 10:20 AM
mahanddeem's Avatar
Check for codes (hidden ones),now....even if CEL is off..
Old Aug 29, 2009 | 11:13 AM
B_Eaze's Avatar
may be time to change your knock sensor
Old Aug 29, 2009 | 12:10 PM
zim5004's Avatar
Always use premium, it is better for your car and it is still cheaper then regular because you end up getting better gas milage which makes up for the 20 cent deiffernece per gallon.
Old Sep 15, 2009 | 10:16 AM
Mayaram's Avatar
Check your codes from Autozone for free. I have a 99 GLE (with 171000) and i have had no problems since i started using Permium.
Old Sep 15, 2009 | 10:41 AM
asand1's Avatar
Cheap gas will cause the knock sensor to retard your timing, costing you performance. It should not cause a CEL or shaking. Poor performance might make it doggy enough to lurch if your motor mounts are worn.
Old Sep 15, 2009 | 11:42 AM
njmaxseltd's Avatar
Not quite, engine knock and ping will cause the KS to retard timing. Most cars run fine on regular. Engine knock (ping) can be caused by a number of things, including but not always related to low octane.
Knock and ping will not set a CEL, a faulty KS will not set it either. What you describe sounds like a misfire. Check for any stored fault codes, they can be stored without the light on. I would suspect a coil pack is getting weak as the 99's are known for it.
Old Sep 15, 2009 | 11:55 AM
IlyaK's Avatar
The Golden One
Yeah, have the computer codes read. You may have a ghost code (pending code) hiding in there. Come back when you find out what it is.
If you haven't done much maintenance on your car do the following:
Fuel filter, spark plugs, run some seafoam through your intake manifold, run some seafoam in a tank of gas, and also check your coil packs. All the info on how to do the above can be found on this site.
Old Sep 15, 2009 | 12:23 PM
FallenOne's Avatar
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
