Brake/battery light on.. alternator right?
Old Aug 30, 2009 | 05:41 AM
Vil's Avatar
Vil
Both came on at the same time yesterday and a quick google search yielded the alternator as the problem, I just want to confirm (This is in a 98).
What should I buy and where should I buy it from? Also the guide in one of the stickied threads is not working so if anyone has a link to one for a 98 max I would appreciate being able to see how difficult this is going to be. Thanks.
Old Aug 30, 2009 | 05:53 AM
j2b4osan's Avatar
you are correct sir. its not that hard if you plug & pull the rad.(I prefer not doing work on my back if it can be avoided.) it can be done in 1hr or less. I would buy from napa above most other sources. AZ has a rep for selling bad ones.
Old Aug 30, 2009 | 05:58 AM
pmohr's Avatar
No more Maximas...
Yes, it's the alternator (most likely).
Where you get it from is up to you, personally I wouldn't get a reman unit, brand new only.
It does seem that motorvate is screwed up again.
http://web.archive.org/web/200801151...ca/mvp.php/500
http://web.archive.org/web/200801161...ca/mvp.php/501
Just note that you do not need to pull the fans, it just gives you a little more room to work.
Old Sep 1, 2009 | 04:21 PM
jholley's Avatar
There is a alternator recall for Maximas manufactured between February 13, 1997 to February 27, 1998. If it was manufactured between this time then a Nissan dealership will replace it at no charge.
My 98 Maxima SE had a new alternator installed several years ago.
Old Sep 2, 2009 | 05:47 AM
The Jackal's Avatar
It seems like people have already answered your question, but yes it is most likely the alternator. The same thing happened to me (95 maxima) about 3 months ago. I pulled the fans to give me more room. It takes about 5 minutes compared to the scraped and soar hands you will be dealing with for a week other wise. I put an autozone one in and it seems to work fine (knock on wood), and it has a lifetime guarantee. It's about 130 less then something from the dealer!
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
