new design for 4th gen motor mount
Old Aug 31, 2009 | 02:36 PM
max ride 41's Avatar
i was talkin to butch at courtesy nissan, the passenger side front mount, ( belt side) was re-designed to help with easing the weight from other mounts thus helping weight dispersion when accelerating. i ordered one, 148.00, you have to buy new screws to go with it. im anxious to see it.
Old Aug 31, 2009 | 03:39 PM
B_Eaze's Avatar
Good stuff.... You know as OP and first to order you r obligate to post pics
Old Aug 31, 2009 | 05:03 PM
aackshun's Avatar
Keep us informed, I had to put all my other modding on hold because now my shifter is moving w/ the accelaration aka I need new mounts...
Old Aug 31, 2009 | 05:13 PM
i'll get the mount next week, i'll be away basking in the sun at the beach!!! as soon as i get back ill be puttin it in and i will def post pics!!
Old Sep 7, 2009 | 09:38 AM
aackshun's Avatar
Give us an update!
Old Sep 8, 2009 | 02:15 AM
ColombianMax's Avatar
I was also gonna get this mount at the dealer but I had some other expenses.. from what the local dealer told me is that most of the 4th gen mounts were superseeded as well as the bolts.
I keep going through idiotzone manual trans mounts, it only holds up for a month and then I have to go buy a new one and return the old one cuz its an order part only. Running on a JY trans mount and I'm just gonna try to get my money back and pick one up at the dealer instead.
Old Sep 9, 2009 | 07:51 AM
Conrad283's Avatar
I need a truck
In for the pics ...
Old Sep 12, 2009 | 09:31 AM
Originally Posted by NissanBeast
Is this new update for all the motor mounts or just a specific side?
Last I talked with parts at nissan it was for most of them. I can verify for ya since i gotta go there anyway
Old Sep 12, 2009 | 09:35 AM
KRRZ350's Avatar
It's made of steel instead of aluminum, and it's basically the same thing as a 5 & 5.5 gen mount, just grab one from the wrecker for an 02/03 and you will usually end up with a nice condition mount.
Old Sep 12, 2009 | 04:07 PM
well, the mounts here and i just got back. frickin rained almost every day at the shore!! 4 inches of rain in 1 day alone!! ( thursday ) as soon as i pick up the mount, ill post picks.
Old Sep 14, 2009 | 05:06 PM
ok, here's da pics of the new oem mount guys, im not seeing any major design change other than the new bolts and the metal base is much thinner than the original???
Old Sep 14, 2009 | 05:22 PM
DAVE Sz's Avatar
Hooooooonda.....
you got that from courtesy? Looks like a flimsy ebay mount to me. Plus it's black. Are mounts from the dealer black now, all of them?
Old Sep 14, 2009 | 05:31 PM
yes, courtesy, and apparently there making the base lighter, ( cheaper imo ) and im not to thrilled with this mount. i agree, it looks like ebay junk.dont know about the painted mount, but i just called to see if i could get the original mount or back order it. this thing looks like $hit.
Old Sep 14, 2009 | 05:42 PM
DAVE Sz's Avatar
Hooooooonda.....
I'm gonna go out on a limb and say they got it from the same supplier as the cheap ebay junk and marked it up a ton. Those ebay mounts have always looked like that. Very disappointed with courtesy right now.
Just to make sure, what part number is it? It came in a sealed NISSAN bag with nissan tags and everything right?
Old Sep 14, 2009 | 06:15 PM
JNCoRacer's Avatar
Just the tip.
Possibly their Key Value part?
Old Sep 14, 2009 | 06:36 PM
yes, sealed up in a nissan bag. part # 11210-2yooe
Old Sep 14, 2009 | 06:53 PM
ok, here's what it should look like.... see any difference, class???
Old Sep 14, 2009 | 10:09 PM
Big difference... wait so which mount is this? the one that goes by the timing chain cover?
Old Sep 14, 2009 | 10:17 PM
yes
Old Sep 15, 2009 | 04:32 AM
Conrad283's Avatar
I need a truck
Hmmm ... That redesign is about as good as the lower radiator support.
Old Sep 15, 2009 | 05:23 AM
ya think???? fickin nissan, i wonder what rocket scientist re-designed the mount. money grubbing ******...
Old Sep 15, 2009 | 07:57 AM
Blackwind's Avatar
i wouldn't put that ish on my kids scooter.
Old Sep 15, 2009 | 09:50 AM
DAVE Sz's Avatar
Hooooooonda.....
It was $150!!!
How much are the normal mounts?
Old Sep 15, 2009 | 11:16 AM
It was $150!!!
Damn, that's an entire engine assembly with accessories and all at the JY lol
Old Sep 15, 2009 | 12:26 PM
FallenOne's Avatar
holy whack batman, thats total
Anyone working at Nissan got the same mounts avail?
Old Sep 27, 2009 | 04:19 AM
well, put her in, looks ok i guess. seems pretty sturdy, its a dampening mount so they redesigned the rubber insert to better move with the engine. ill post pics when it decide's to stop raining.
Old Jul 7, 2014 | 08:23 AM
Alaskus's Avatar
Bumping an old thread I know...
Max I know you are still around, get you tell me what procedure was in replacing the bolt for the mount? The one the mount slides onto? Vice grips? Thread c
Locker at all? Thanks man!
Old Jul 7, 2014 | 03:20 PM
ugufru's Avatar
I don't know why I'm bumping thing except that I feel that it should be pointed out that the old mount appears to be aluminum and the new "cheap ebay" ones appear to be made out of steel. Wouldn't they be thinner for that reason? Does anyone have 5 or 5.5G mounts to post for comparison?
I'm probably putting new ones in a 1995 SE.
Old Jul 7, 2014 | 03:21 PM
ugufru's Avatar
Old Jul 7, 2014 | 09:09 PM
Alaskus's Avatar
Yes, one is aluminum and the other steel.
The issue that I am having, and have risen this thread from the grave was not about that point. Since the aluminum ones are far and few between, and to use the more abundantly available steel mounts, I (and you) would need to swap out the hardware in the mount bolted to the timing cover as the threads do not line up right with the thinner mount.
So hopefully Max Ride 41, or another org'er can give a bit more detail on their experience.
Old Jul 8, 2014 | 05:40 PM
CS_AR's Avatar
Once you get a new mount installed or decide what to do with the old one, you might want to look into a torque bracing bar. I love the one that's installed on the 99 SE 5MT. Also, I can tell it is saving the engine mounts.
Here's a thread on the topic below.
http://forums.maxima.org/5th-generat...t-opinons.html
Old Jul 9, 2014 | 05:38 AM
CMax03's Avatar
Any Nissan brands on it? Looks like some afftermarket crap! But those 2 vertical blocks on the middle elastomeric portion is new in the design...I would fill the voids with 3M Window Weld now while it's out and let it cure for about 2 days in the sun!
Old Jul 9, 2014 | 08:26 AM
Fakie J Farkerton's Avatar
2009
Old Jul 9, 2014 | 06:59 PM
it's a nissan mount that i got from courtesy as i stated in earlier post. i did'nt save the bag it came in and this thread is 5 years old+. if you want the original mount you can go to a j/y as stated and throw new polyurethane bushings in.
Old Jul 9, 2014 | 08:31 PM
Alaskus's Avatar
You swapped the hardware though? The bolt, i mean so it would accommodate the steel vs the aluminum height? how did you go about the swap of those? Vice grips/thread locker?
Old Jul 11, 2014 | 06:57 PM
Trini Boom's Avatar
You do need the bolt to replace the mount completely. Be advised if you are doing the tranny mount, it was also redesigned as well and is no longer aluminum and will need to reorder 4 new bolts.
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
homeyclaus
Sep 3, 2015 06:15 PM
Rage Maximus
Sep 3, 2015 12:26 PM
george__
Aug 18, 2015 07:06 PM
