Random hard starts.....
Old Sep 2, 2009 | 06:33 PM
caseymaxima's Avatar
Hi Everyone,
At random times my 96 4th gen with 126,000 miles on it has a hard time starting. The best way to describe the starting issue is that it feels like the engine almost is seized, or like kick back when attempting to pull start a chain saw or lawn mower. You can feel the starter motor stop spinning, almost like it can't actually turn the engine over. Then you turn the key again, and the car starts perfectly. There is no rhyme or reason to when the car does this. Do you have any ideas?
Oh and when the car is running, it runs perfectly. I do have a CEL po400 (I guess the EGR tube) but I have not had a chance to deal with that, but I doubt that could cause the starting issue?
Thanks,
Zack
Old Sep 2, 2009 | 07:01 PM
Nopike's Avatar
That's how mine was, made noises like you describe. The starter is too weak to turn the engine over. Don't know how old your starter is but........
http://forums.maxima.org/4th-generat...ike-champ.html
Lesson learned is, if your starter is more than ten years old and you have starting issues there is a good chance they are being caused by the starter. Had I know that the starter was so (relatively) easy to remove I would have gotten it tested.
Old Sep 3, 2009 | 06:05 AM
JtzMax's Avatar
Whatchyou say?
Get used to it ... you drive a 4g! lol Mine does / and has for some time / the same thing. My starter is fine, no problems .... even does it after replacing the starter.
Old Sep 3, 2009 | 07:03 AM
Nopike's Avatar
Check that the connections at your battery and the starter are clean and tight.
Old Sep 3, 2009 | 11:43 AM
Ringo1965's Avatar
1997 Nissan Maxima SE
Another starting problem-replaced just about everything
I've been having this problem for about a month just a few days after a clutch job. I can get it to start but it some times takes a while. Sometimes when I'm cranking the engine, it will crank and then stop suddenly and then resume cranking.
Here is a video from tavarish of his car trying to start. Listen to the pause he gets while cranking.
http://www.youtube.com/watch?v=OIpAaHfsuxU
No codes either
Edit: When I had a guy from nissan hook up a computer to the car in the back parking lot He noticed the POS reading fluctuating wildly, so I replaced the Crank sensors and nothing.
I've replaced the following-
-spark plugs
-ECT sensor (engine coolant sensor)
-crank sensor
-crank ref sensor
-camshaft sensor
-ignition switch
-switched batteries
-4 of the 6 coils are fairly new
-fuel filter within 10K
-2 different starters from a junkyard, both 10 tooth. No one seems to have an 11 tooth starter unless I buy a new one. One was from a 96 and one was from a 99.
UPDATE: An 11 tooth starter from an 01 has been added without solving this, but improving it slightly.
Any ideas would be appreciated!
EDIT: PROBLEM FIXED!- http://forums.maxima.org/showpost.php?p=4716170&postcount=130
UPDATE:
9/30/06
Had some starting glitches come back so I added more wires to the starter and the starts are ok again, guess my grounds on the tranny were worse than most peoples.
Starter has 4 ground wires running to it.
3 8ga (2 of them are running directly to the neg terminal)
1 10ga
Tranny has 2 12ga still.
This thread(thanks to C MAX's advice) has helped the following solve thieir starting problem: crazy97, KRRZ350, vj72ct, Mishmosh, Ptatohed, Vettefever5, Tavarish, Mxzmax, White Shadow, T love, Max Gator(5TH GEN), acidspit86, prince starbai, JaTan, oVeRdOsE, liquidx, serfer420, UT-Max, wwjd180, maxihari77SE96, momay, Ham1987, liqidvenom, mistuhjj, mansurxk, TunerMaxima3000, 1chewabacha1, titanbk, miserov, Kidyahoo1, smai555, foxracing12, azn_mint, Peter1
Old Sep 3, 2009 | 11:47 AM
This is such an odd issue. The starter is about three years old. When everything is working ok, the starter motor spins the engine over perfectly. Could the starter still be at fault?
Thanks,
Zack
Old Sep 3, 2009 | 12:20 PM
Nopike's Avatar
Probably worth pulling the starter and getting it tested.
Old Sep 3, 2009 | 03:29 PM
DizzyEdge's Avatar
What does that mean?
I just wanted to confirm that this is a different problem than the "engine starts after 2-8 seconds of cranking randomly" problem?
Old Sep 3, 2009 | 04:55 PM
Yes, totally different. The car actually stops cranking, again almost like the engine is seized, or like kick back from a pull start on a chain saw. So you must let off on the key, and try again. Usually when you try the second time, it fires up perfectly. The second time the starter spins great, with no problems at all.
Zack
Old Sep 3, 2009 | 04:57 PM
No codes either
-spark plugs
-crank sensor
-crank ref sensor
-camshaft sensor
-ignition switch
-switched batteries
UPDATE:
9/30/06
1 10ga
My car sounds totally different from the youtube video. My car actually stops cranking. That car just keeps cranking in the video.
Thanks,
Zack
Old Sep 3, 2009 | 07:30 PM
Leo_Koneval's Avatar
Check your ignition switch and stuff some tape into the slot of the switch. I had a gap form in the + shape of the switch and when I turned my key to START the switch itself would not turn all the way and so it made my car sputter and die occasionally when starting and it would take two or three tries before it actually starts.
Old Sep 4, 2009 | 07:39 AM
al7601's Avatar
check battery and starter, had the same problem, turned out to be the starter. get it checked before you get stranded.
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
jaydot901
Sep 29, 2015 01:18 PM
