A/T service
Old Sep 6, 2009 | 07:38 PM
NISSANMAXIMA91's Avatar
A/T service
Been working on my 96 Maxima for the last couple of months, and getting ready for it to all go back together. I have the automatic transmission out as of now, and was wondering if anyone had any suggestions of things I should do maintenance wise while it is out of the car. Obviously the fluid is out, so it will be fresh. I have new axle seals ready to put in it. I also will be replacing the pan gasket. It currently has 176-177K on it. Only real issues were that it would shift a little hard every once in a while in first and second. Other whise no major issues. Any suggestions would be appreciated.
Thanks,
NM91
Old Sep 6, 2009 | 09:18 PM
Quickywd01's Avatar
I did a drain and fill with amsoil atf and it helped. Also put in a b&m 70255 cooler.
Old Sep 6, 2009 | 10:07 PM
trooplewis's Avatar
That seems to be the norm for most 4th-gen automatics. First-to-2nd, firm hard shift, next two shifts smooth and easy...
Old Sep 7, 2009 | 08:04 AM
Kickin_Wing's Avatar
If you're really worried about it, or if you're feeling ambitious, you should pick up a rebuild manual. You can most likely pick up a rebuild kit from transstar here: http://www.transtar1.com/rebuilders.asp. They have six different levels of "rebuilding" to suit each job or what you feel comfortable doing yourself.
Old Sep 7, 2009 | 11:22 PM
Lickapimp8's Avatar
Trans Problem need help ASAP!!!
I have a 95 maxima and i have changed the solenoids in the auto trans. Drove the car to cali and back to jersey and three months later i have no reverse gear and nothing happens in 1st gear. It never slipped gears. It never shifted hard in any gears. i put it in drive and it feels like the car only has 3rd and 4th gear i checked the codes with a scanner and this is what i got
P1760-Overrun Clutch Solenoid Problem
P0740-Torque Clutch Converter Solenoid Problem
P0745-Line pressure Solenoid Problem
P0731-1st gear Shift Problem
P0732-2nd gear shift problem
Any help with any solution will be much appreciated
Old Sep 8, 2009 | 09:25 AM
http://forums.maxima.org/4th-generat...e-posting.html
Not thread hacking would be much appreciated.
Old Sep 8, 2009 | 04:40 PM
lol. Newbie pwned by a newbie. And seriously. You do have newbie forums for that reason.
my03maxima
Jul 28, 2024 07:40 AM
Excalibur23
Oct 13, 2015 04:33 PM
RealityCheck
Oct 2, 2015 06:34 PM
Max8
Sep 22, 2015 02:53 PM
Pixel
Sep 15, 2015 05:53 AM
