ecu installation and weird idle
Old Sep 9, 2009 | 01:36 PM
Shift_Nismo's Avatar
I had another ecu installed in my Max yesterday, and since it was installed, the idle has been really low. When I went in, my idle was fine, but after the install, it was low, like between 300-400, and sometimes it felt like it was gonna shut up. This morning I had to give it gas to keep it from shutting off when I first started to drive. Would this happen if the mechaninc didnt perform the idle relearn procedure? And what procedures must be done when an ecu is changed? Im not getting any codes, so Im assuming everything mechanical is fine, and it didnt start until after the ecu was installed.
Old Sep 9, 2009 | 02:50 PM
f550maranello2's Avatar
redo the idle procedure and check it out.. i never had a problem with idle with any ECU...
maybe he was messing with it?
Old Sep 9, 2009 | 04:57 PM
The ecu itself seems fine. How do I relearn the idle?
Old Sep 9, 2009 | 06:17 PM
pmohr's Avatar
No more Maximas...
There is no 'idle relearn' on the A32, really.
Are you sure the diagnostic screw is fully in the correct position?
Have you tried swapping back to the other ECU to see if the idle goes back to normal?
Old Sep 10, 2009 | 09:01 AM
Is the correct position the direction of the blue mark? if so, then yea its in the correct position
Old Sep 10, 2009 | 10:30 AM
yea that should be ok.. unless i had it turned 1 turn or something..
Old Sep 10, 2009 | 01:08 PM
DAVE Sz's Avatar
Hooooooonda.....
screw should be turned all the way to the left...
Old Sep 10, 2009 | 07:33 PM
Ive got a question, ive just found a ok to big sized hole in my exhaust system, and that will be getting fixed this weekend, could that be creating or contributing to my low idle? If so, why was my old ecu idling fine at 5-600?
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
pktaske
Sep 4, 2015 08:40 AM
