P0135 p0155 p0141 p0161 grrr
Old Sep 11, 2009 | 07:54 AM
CautiousDriver's Avatar
i have a 99 cali spec maxima with fed manifold and fed y-pipe and these codes with o2 sim remain. one guy suggested heater resistor wont work. driling bung holes i don't want to do .
Please... How do I get rid of these codes I can't pass inspection been driving with a bogus sticker for over a month now.
i Know this has been covered in other posts, What WILL WORK?
I have read through posts on this and with someone(guy is knowledegable) telling me that heat resistor won't work i don't know what to do .
Old Sep 11, 2009 | 08:12 AM
IlyaK's Avatar
The Golden One
I have an o2 sim, fed spec headers and y-pipe.
Are you sure your sim is working/plugged in correctly? I have none of these codes. Did you get a dual output sim? Or a single?
Old Sep 11, 2009 | 09:56 AM
ok so my sim o2 went bad and i had it connected for less than a year. had white to one sensor and the other black,red and white to another sensor.
Ilya so you're saying if i connect a good sensor the same way it should resolve my issue?
and yea dual output is what i had purchased from 02sim.com
Last edited by CautiousDriver; Sep 11, 2009 at 09:57 AM. Reason: and yea dual output is what i had purchased from 02sim.com
Old Aug 3, 2011 | 05:25 PM
pc99maxima's Avatar
my p0141 code wont go off... cleared codes and everything and just replaced sensor 1 bank 2.... what should i do next?
Old Aug 4, 2011 | 10:31 AM
bobflood's Avatar
According to FSM, P0141 is rear O2 sensor (Cal spec Bank1 Sensor 2; Fed spec just Sensor 2) behind the cat. If you replaced sensor 1 bank 2, you replaced front sensor on forward cylinder bank.
Old Sep 29, 2011 | 01:22 PM
yea so replaced all sensors. nothing anyone know of a good diagnose mechanic who will ook at this issue. i think because of this issues when i drive hard my card ona turn would sometimes just die, scary feeling when driven with one hand. it's automatic 99 converted from cali to fed spec
sake1bs
Sep 19, 2015 09:32 PM
Kruppa
29
Jan 31, 2014 02:23 PM
ukmastermind
Sep 19, 2004 12:40 PM
nismos14
24
Mar 3, 2004 11:28 AM
