80 MPH - Car Shakes
Old Sep 14, 2009 | 04:50 PM
Michael01127's Avatar
80 MPH - Car Shakes
Once i get around 80 MPH My steering wheel starts to wobble a lot and it seems like the car is shaking a little, like it almost feels like my tires are going to pop off the car.. lol
im not sure what the problem could be but i do know that my tires are starting to get pretty low tread.
could it be that? or i was thinking maybe alignment & high speed balance?
or could it be the mixture of all 3?
i mean i would like to feel safe in my car when driving at that speed, and would like to be able to drive faster.. but at the moment i cant so whats best way to solve this?
Old Sep 14, 2009 | 04:53 PM
Q8BallMAXIMA's Avatar
New tires........alignment...... Your probably hitting your warning ribs on the worn tires.
Old Sep 14, 2009 | 04:58 PM
Feldman's Avatar
sounds like your tire's are out of balance. I wouldn't really waste your time getting them balanced though since you are in need of a new set. Any place you get them put on will balance everything when they mount the new tires as part of the mounting process.
Old Sep 14, 2009 | 05:48 PM
98nismomax's Avatar
i had the same problem back in January. I found out that it was my front end alignment was all messed up and to top that off my front struts were shot, my best bet is that you just need alignment.
Old Sep 14, 2009 | 06:00 PM
maxima-junky's Avatar
^^^ I used to get a shimmy at 120 in my VE. It turned out to be tires and balancing. I switch the front to the back and vice versa and the shimmy stopped.
Old Sep 14, 2009 | 06:14 PM
JNCoRacer's Avatar
Just the tip.
Speeding...
Old Sep 14, 2009 | 06:18 PM
Originally Posted by JNCoRacer
Speeding...
I meant to say I got a shimmy at 20...yeh.....20 mph.
Old Sep 15, 2009 | 07:55 AM
ajm8127's Avatar
That's a good idea, rotate your tires, set the air pressure to the recommend and psi, and see if that affects the vibration. If it does, then its your tires, if not, its something else. Even if the rears are unbalanced also, the vibration should at least be different.
Old Sep 16, 2009 | 05:51 PM
l ZR1 l's Avatar
The Balance is off. Take to your tire shop si they can balance and align the car. That will solve your problem
Old Sep 17, 2009 | 10:31 AM
Galager's Avatar
Don't spend any money until you get new tires. You'd be surprised how worn tires, even if not completely gone yet, can change. Ride quality degrades, noise increases, it may simply be the tires. Once you get them, you should get an alignment and balancing then anyway. If the problem persists, then start chasing things down.
Old Sep 17, 2009 | 11:52 AM
el_colombiano's Avatar
yeah i have the same problem waiting on some cash to get a new set of tires
Old Sep 17, 2009 | 11:56 AM
showdown's Avatar
Because I Can
if u have 22's on ur car or super heavy wheels at stock height...its going to shake...
Old Sep 18, 2009 | 01:11 PM
Finally just got all my problems solved
got 4 brand new tires mounted and balanced / front and rear alignment as well as a lifetime road hazard protection warranty for a toltal of 457.55
does that seem like i paid a decent price? or over paid?
Old Sep 18, 2009 | 01:29 PM
Galager's Avatar
Sounds like a good deal to me, depends on the tires of course...
Old Sep 18, 2009 | 01:47 PM
well they were all season. and they have a 55,000 mile gurantee on it
as well as if i hit any pot holes or nails etc they will replace it
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
jhontelj
Aug 17, 2015 04:07 AM
Gsantos79
Aug 8, 2015 07:41 AM
