brake pads ??
Old Sep 16, 2009 | 04:46 PM
jav24's Avatar
brake pads ??
hi i have a 96 maxima and my brother has a 97 altima i need brake pads and my brother has lifetime on the pads for his altima so i was thinking if the pads from the altima will fit my maxima so i can use his warranty
Old Sep 17, 2009 | 07:36 AM
njmaxseltd's Avatar
Huh?
Just about any brake pad you can buy for your Maxima comes with a lifetime warranty. FYI the warranty does not cover normal wear, only failure of the part.
Old Sep 17, 2009 | 02:07 PM
Phaedrus220's Avatar
100 posts/7 years - woot!
There are two different sellers of brake components in the GD section, each with a bazillion positive reviews, have you not looked? pads are cheap.
Old Sep 17, 2009 | 04:49 PM
XeroX's Avatar
Hella internets
Wierd question...ur better off buying new pads man...seriously...
im pretty sure that the calipers do not use the same pads anyways, take em out and compare em...
Old Sep 17, 2009 | 07:09 PM
7jackmack's Avatar
Originally Posted by njmaxseltd
Huh?
With over 325,000 miles ,I've replaced my brake pads many times under
warranty with just normal wear and have never had any problem getting the warranty honored.
Old Sep 17, 2009 | 07:15 PM
haydeno's Avatar
There is a $20 rebate on monroe pads(work fine for me) and they are $28 on amazon free shipping= $8
Old Sep 17, 2009 | 07:23 PM
nafddur's Avatar
Wrong - the lifetime warranties I get with pads bought at AZ include normal wear and tear. I've done the pads (both fronts and rears) several times in 208K miles, and only bought the first set. Sometimes they want you to pay the price difference in pads (or give you a refund if you put cheaper ones on) and sometimes they give you more expensive pads at NO extra cost. Depends who is behind the counter on the day you make your exchange.
I also believe the `limited' part of the limited lifetime warranty means it is only good for the original pad purchaser.
Old Sep 18, 2009 | 07:16 AM
njmaxseltd's Avatar
Interesting, I stand corrected.
So tell me why you need your brothers Altima pads when you already have pads that are covered under warranty?
Still makes no sense......
Old Sep 18, 2009 | 09:25 AM
kisas's Avatar
get a Wrangler ThermoQuiet, check advance auto parts, they have some promotion going on
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
