stock air box removal
Old Sep 17, 2009 | 06:00 AM
RUDENESS's Avatar
i wanna remove the stock air box and add a cold air intake, help me out guys..
Old Sep 17, 2009 | 06:01 AM
JNCoRacer's Avatar
Just the tip.
You should really read the stickies and FAQ's more.
Old Sep 17, 2009 | 07:29 AM
njmaxseltd's Avatar
Nooooooooooooooooooooooooooooooooooo
Old Sep 17, 2009 | 08:24 AM
Leo_Koneval's Avatar
Fine fine I'll help you out, from what I remember you will need to remove a few bolts and screws. Removing the battery is helpful if you want to get EVERYTHING out.
What I did when I took off my air box was to first remove the top part, you know the part that goes to the TB, then I went to the snorkel and removed the two screws at the tip but before removing it, you have to kind of follow it down with your hands and there should be a sensor at the bottom, and then unhook the snorkel from the resonator box (Under the battery) and pull it out. Then to take out the box under the battery, you need to use a SMALL ratchet and there should be two loooong bolts holding it on, one should be right under the battery also, the other one is under a fuse box I think and you need to remove the two screws on the sides of the box to move it to the side to get the the last bolt holding on to the resonator box.
I didn't get any further than that because I wanted to keep my stock air box, but all you need to do I think is remove the 4 or 5 bolts holding on to the bottom of the box and it should just pop right out.
Old Sep 17, 2009 | 08:25 AM
secondtonone317's Avatar
nycnissans
Just grab on it and yank really hard.
Old Sep 17, 2009 | 09:10 AM
IlyaK's Avatar
The Golden One
^^ win.
Old Sep 17, 2009 | 09:26 AM
ThreePointO's Avatar
you want help? keep ur stock airbox. Its kinda a p.i.t.a to take out, and ur just gonna end up putting it back in any way.
Old Sep 17, 2009 | 10:07 AM
IlyaK's Avatar
The Golden One
It's not that hard guys...it's not rocket science.
- Undo all hoses going to mid-box
- Unclip the top part of filter box
- Loosen clamps around TB and MAF
- Unscrew clips in radiator support holding the snorkle
- Remove sensor from Snorkle
Remove intake.
Done.
I know some people are scared to do anything on their car, but just look. You'll see how simple it is.
Old Sep 17, 2009 | 10:35 AM
JNCoRacer's Avatar
Just the tip.
^This.
Old Sep 17, 2009 | 11:18 AM
bigpopaj369's Avatar
Remove intake.
Done.
agreed! it is mad easy and same with reinstalling it
Old Sep 17, 2009 | 11:31 AM
WhiteMaxima9600's Avatar
Do you have a cold air intake to install yet? If not, I would hope you wait to remove your stock box.
Old Sep 17, 2009 | 11:59 AM
njmaxseltd's Avatar
The stock setup is a cold air intake.
Old Sep 17, 2009 | 08:31 PM
FallenOne's Avatar
Sure if you want to lose power go for it!
Old Sep 18, 2009 | 06:43 AM
Coolsaber57's Avatar
but it's not loud and ricey enough!
Old Sep 18, 2009 | 10:03 AM
Kickin_Wing's Avatar
If you have to ask, maybe you shouldn't be working on your own car...
Old Sep 18, 2009 | 02:17 PM
SrgScott's Avatar
Hack the air box.
Old Sep 18, 2009 | 04:07 PM
FallenOne's Avatar
Wow, If hes incapable of doing this himself than dont give him a complicated task, OP all you Really need to do is Tape Over the resonator hole on the underside the snorkel.... thats about it...
Old Sep 18, 2009 | 07:32 PM
RUDENESS's Avatar
Damn you guys are something else, just answer the question mannnnn, look I know that some hoses have to be blocked off thats all im asking...
Old Sep 18, 2009 | 07:33 PM
Look I know that some hoses have to be blocked off thats all im asking...
No hoses need to be blocked off. Ima PM you right now..
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
