removing stuck caliper bolts
Old Sep 18, 2009 | 06:10 PM
SSzretter's Avatar
So I did pads/rotors for 3 of 4 wheels so far. One rear wheel was easy, 15 minutes.
The other two took HOURS, all because of the caliper mounting bracket bolts.
I broke one in the back, and the one in the front I never could get out so I had to get a whole new caliper/braket.
So I need thoughts on the last one...
I tested it tonight, tried a wrench and a socket.
Banged it with my hand, pushed...
Used some PB spray (3-4 applications) and some rust treatment and kept trying.
Tapped the bolts with a hammer on the head.
Still not budging.
Tomorrow I will probably give my air gun a try, but I just get nervous about the bolt breaking.
I have not tried heat, though I do have a torch. Heat did not work on the other bolts though.
I read on another site some people heat the bolt and apply wax (candle) as a lube...?
Any other thoughts?
What are these mechanics doing that I am not?
Old Sep 18, 2009 | 06:44 PM
pmohr's Avatar
No more Maximas...
Sometimes there's just nothing you can do, bolts break.
What exactly are you having issues with, the caliper-torque member bolts, or torque member to knuckle?
Old Sep 18, 2009 | 07:51 PM
QNO_A32's Avatar
just use your gun
Old Sep 18, 2009 | 08:34 PM
SSzretter's Avatar
It's the torque member bolts. I got the caliper bolts loose already. Another thought, I have a set of Irwin bolt extractors, maybe I will try those...
Old Sep 18, 2009 | 09:38 PM
haydeno's Avatar
mine wouldnt budge with hand tools but came off instantly with air
Old Sep 21, 2009 | 10:43 AM
Phaedrus220's Avatar
100 posts/7 years - woot!
Heat is your best friend, especially if you can get the frozen part off. Last brake job / overhaul, I had to put a torch on one of my caliper pins for about ten solid minutes, it finally popped out like a champagne cork. Good thing I wasn't staring at it at the time
Old Sep 21, 2009 | 10:46 AM
MOHFpro90's Avatar
Get some Aerokroil. Call around town see if you can find some. Best lubricant ever, no questions asked. Its in a 22 oz (I think) orange can, costs about $15. Itll take em off.
Old Sep 21, 2009 | 06:39 PM
Blakfreestyle's Avatar
Just some advice
Hey I seldom post on this forum... But, if you do get this bolt off, replace it afterwords. Don't be cheap and re-use a bolt that has been over-torqued and distorted. Go to the dealer or good auto parts store for a replacement.
Also, don't be afraid to cut off the bolt and use the extractor to get it out.
Old Sep 24, 2009 | 10:41 AM
mantle7yanks3's Avatar
put a breaker bar on the bolt and bang the end of it with a rubber mallet and it should come losse with just a hit or 2
Old Sep 26, 2009 | 02:11 PM
Mistertones's Avatar
When I changed my rear drivers side, the bolt broke. I used a breaker bar which helped out a lot.
Old Sep 26, 2009 | 02:20 PM
SteveB123's Avatar
What exactly would be the advantage of doing that?
Old Sep 26, 2009 | 02:27 PM
playground's Avatar
you do remember to turn it CLOCKWISE since they are facing the other way ritght?
The Frye
Sep 2, 2021 11:03 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
bumpypickle
Sep 19, 2015 01:07 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
Colossus
Sep 9, 2015 05:46 AM
