Still No air/ No heat
Old Sep 29, 2009 | 07:57 AM
Pizatt's Avatar
Ok, so I thought it might have been the blower motor, so I got a brand new one and still no luck. There is no air, no heat, nothing is running. Seems like there is no power to the motor at all. (Plugged the motor to another battery source and it worked)
What could be the problem?
FYI- I have a 1999 I30 if that makes any difference.
Old Sep 29, 2009 | 08:05 AM
mtrai760's Avatar
'Trynna' is not a word
Seriously, download the FSM and go through the troubleshooting steps. That will save you a lot of money vs. replacing misc parts until you get lucky.
Old Sep 29, 2009 | 08:56 AM
Pizatt's Avatar
What is the FSM? and where do I find it?
Old Sep 29, 2009 | 09:14 AM
mtrai760's Avatar
http://forums.maxima.org/general-max...niti-fsms.html
Old Sep 29, 2009 | 07:56 PM
talisman311's Avatar
your fan amplifier blew..happened to me a few months back @ 155k miles.
Old Sep 29, 2009 | 09:32 PM
FallenOne's Avatar
and you dont know what an FSM is?
Old Sep 30, 2009 | 07:10 AM
njmaxseltd's Avatar
Auto or Manual climate control?
If it's Auto, then it's the fan amplifier
If it's Manual, then it's the blower resistor
Old Sep 30, 2009 | 11:29 AM
snarf8008's Avatar
Yep, blower motor resistor/amplifier.
Old Sep 30, 2009 | 12:23 PM
fflint_18's Avatar
Ditto. Wow
Old Oct 1, 2009 | 05:46 AM
slfalco's Avatar
Same thing for me (auto climate control).... Fan amp went, caused by very worn motor brushes.. Replaced both amp and blower... Also the amp can be repaired if you have some soldering skills (the part is very expensive, over $100)... I ended up getting soaked at the dealer for a new one (happened day before we were going on vacation, so had to be fixed), then I repaired my old one using this:
http://forums.nicoclub.com/zerothrea...postid=4870036
Old Oct 1, 2009 | 12:35 PM
ajcool2's Avatar
Check the DCMAX section and you'll see why our post counts are so high.
Old Oct 1, 2009 | 01:41 PM
Pizatt's Avatar
Thank you for the input. Its an Auto Control. So its the Fan amplifer. Will get that change ASAP. Hope that fixes that problem.
BTW who cares about post counts? If I am unsure about something, I ask. (Learned this very early in life, and its brought me a long way) I thought FSM meant Full Service Manual, but who knows with all the three letter lingo on the .org.
Thanks again, Much appreciated
AJCOOL... They just don't know...LOL
Old Oct 1, 2009 | 01:50 PM
Pizatt's Avatar
Thanks, Needed that for sure!
Old Oct 1, 2009 | 02:28 PM
Pizatt's Avatar
Yikes just called Infiniti Parts and they said $328.00- Definitely need to find a cheaper solution.
Old Oct 1, 2009 | 02:50 PM
ajcool2's Avatar
Hey I'll probably be hitting the junkyard this weekend so I'll look for that part for you. I know theres a few I30's there for sure. I'll let you know what I find.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
