Eibach Camber Kit - $20 Mod---Look Inside!
Old Nov 30, 2001 | 05:33 PM
tifosiv122's Avatar
Hey. So I took the dive and spent the $20 nobody wanted to spend and bought Eibach's camber kit. It was $25 at www.carparts.com and with their 10% off thing it came out to $2X.XX after shipping. It finally came, after 10 days and it consisted of 2 bolts. See pic. It also came with these instructions:
Installation of EZ Cams
1. Take alignment readings and determine amount of camber change needed.
2. Raise vehicle by body pinch welds. Remove tire and wheel assembly.
3. Remove the upper strut-spindle bolt. Line up small tab with pin on bolt. Install bolt with large tab out toward wheel for positive camber or in away from wheel for negative camber. Add lock nut, snug, but do not tighten. Loosen the lower bolt.
4. Reinstall tire and wheel assembly and recompensate alignment equipment. Rotate EZ Cam bolt to obtain desired camber reading.
Torque bolts as follows
(do not exceed)
@ 36 ft lbs
5. Complete aligment and road test vehicle.
The link to the carparts part is:
http://www.carparts.com/parts/newsea...toidsearch=YES
This will be installed hopefully by next friday. I will post more results then.
Erik
Old Nov 30, 2001 | 06:21 PM
DaEnigma's Avatar
I got these when I purchased my eibachs, but I never put them on.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
