Installing UDP
Old Nov 30, 2001 | 08:50 AM
SuDZ's Avatar
Installing UDP
Hi,
I was having alot of trouble getting off the bolt that holds on the UDP. I need to remove it to put on the one I got from Unorthadox Racing. I even tried with air tools and 120 pounds of pressure. Still wont come off. Is it reverse threaded or anything like that? Is there another idea to go about when trying to get it off?
SuDZ
Old Nov 30, 2001 | 09:13 AM
ejj's Avatar
ejj
Re: Installing UDP
Originally posted by SuDZ
Hi,
SuDZ
120fl-lbs won't do it...you'll need somewhere in the range of 150+ to get it off. Its really on there.
If your tools can't do that, you can use your wonderful 200fl-lbs of torque that your engine produces to do the work for you. Put a breaker bar on there, brace it agains the frame towards the front of the car, and crank the engine. Don't start it, just crank it. I don't recommend that though!
Old Nov 30, 2001 | 09:28 AM
SuDZ's Avatar
Re: Re: Installing UDP
150 wow. I dont know if I can go that high or not. My extention piece I was useing actually broke in half at 120. Crap. Maybe someone else I know has one that can take it.
SuDZ
Old Nov 30, 2001 | 10:30 AM
njmaxseltd's Avatar
Re: Re: Re: Installing UDP
SuDZ
Please don't tell us your using a 3/8" drive to do this job?
Go get a good quality 1/2" drive and a breaker bar with a pipe on the end. That should do the trick!
Old Nov 30, 2001 | 10:54 AM
Lime's Avatar
OKay, the best thing to do is find a shop with tools that will help you; it's the safest way. I have friends who manage Monro shops and such. See if you can get someone to give you a hand after hours or whatever. They are usually kewl about that. Anyway, the 3/4" (powerful) impact guns are the only ones that do the trick, trust me.
Old Nov 30, 2001 | 01:16 PM
SuDZ's Avatar
Re: Re: Re: Re: Installing UDP
I actually have to pick up a 1/2 inch because of the other one breaking and all. Hopefully it will come off soon. As far as the breaker bar, how did you do this? Was it on a lift? Because I was gonna try a pipe or what not but not enough space underneath to use it effectivly. Just curious.
SuDZ
Old Nov 30, 2001 | 01:43 PM
plrod Black 95 SE's Avatar
Mine came right off with a 1/2" impact and an impact socket at 90 PSI air pressure; suggest you follow the directions and remove the starter though. Don't do it with the cranking the engine method.
Old Nov 30, 2001 | 06:26 PM
DaEnigma's Avatar
I got mine off with just a MetWrench box-wrench and a cheater bar, But mine only had ~8k on it.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
