R34 fitment issue
Old Oct 9, 2009 | 05:15 PM
LLZuB's Avatar
R34 fitment issue
hey guys,
I just installed an r34 retro on my maxima, but it seems im getting a little gap where the headlight meets the fender
The guy I bought the r34s off didn't send me a bracket, an dim thinking that could be the issue from my reading on the .org
When i push the headlights in the touch the fender but don't stay there, and i've realized that theres only screws on the side closest to the grill holding the lights in, is there a bracket im missing that goes on the other side? anyone got any pics of theres so maybe i could fabricate something?
its not a huge gap but its noticeable to me and i've seen these lights fit perfectly on many other maximas
Old Oct 9, 2009 | 06:21 PM
TSoprano's Avatar
L bracket with 2 holes to mount on fender and 1 hole to screw light..
Pic courtesy of ewuzh from this thread..
http://forums.maxima.org/4th-generat...installed.html
Old Oct 9, 2009 | 06:55 PM
tigersharkdude's Avatar
i had that same gap, even with the brackets. if you cant fix it, ive heard of ppl taking rubber base board molding and cutting off a piece to close in the gap. IDK if works though
Old Oct 9, 2009 | 06:57 PM
LLZuB's Avatar
Hmm thanks guys, I was told to try bending the stock mounting tab a bit
anyone tried that?
Old Oct 9, 2009 | 07:47 PM
you will have better luck if you search for the cefiro lights install. since they dont fit the maxima right, thats what most guys do
Old Oct 9, 2009 | 08:13 PM
TSoprano's Avatar
You could bend sht all day but you still need 3 mounting points to hold your lights on..
Here's another pic to help you see whats wrong.. The hole between the corner and low beam is what the silver screw from the first pic goes into.. As you tighten the silver sheet metal screw it will pull the corner in towards the fender closing the gap and holding your lights in place..
Old Oct 9, 2009 | 08:57 PM
odequiat's Avatar
Interesting thought, i completely agree with your perspective
Old Oct 10, 2009 | 03:44 PM
LLZuB's Avatar
Well I bent the stock mounting tab out of the way, and used some L-brackets to bring the lights in and hold them into place better, theres still a little gap but i think it's because the stock headlight bolts I used were too short and didn't pull them in enough, So i'm going to grab some longer bolts and hopefully that will do it! The gap is tiny now compared to before so im more satisfied now
Old Oct 10, 2009 | 05:45 PM
lets see some pics when done. Id like to know how it looks
Old Oct 10, 2009 | 05:50 PM
LLZuB's Avatar
Will do, I went out and took some Cut-off pics of the projectors at night so here those are:
Pic of before the bracket modification and with 8000k HID bulb (please disregard the condensation, it will be fixed tomorrow lol:
Pic of new 4300k cut off:
Old Oct 10, 2009 | 06:21 PM
Flava_24/7's Avatar
Boosted Panda
Why do they flare up towards the ends like that? Looks as if the cutoff is curved upward.
Old Oct 10, 2009 | 06:25 PM
LLZuB's Avatar
Hmm im not to sure, i might have to do a little adjusting, I bought them off another member, so I just installed them hoping they'd be aimed properly, but I guess not, any hints for adjusting? or anyone know what would make them flare up like that?
Old Oct 10, 2009 | 07:08 PM
petro2342's Avatar
Mine flare upwards like that too. I tried adjusting and had no luck. Guess how the projectors are?
Old Oct 10, 2009 | 08:00 PM
Coolsaber57's Avatar
Or the lenses.
My stock TSX clear lens is straight as an arrow, but the Retrofit source clone isn't.
Old Oct 10, 2009 | 08:14 PM
LLZuB's Avatar
Hmm.. just a thought, do you guys think maybe the bulb holders are upside down causing the bulbs to be upside down?, would this make a difference at all? does the return rod sit facing up or down? I jut installed them how they came so ill take a look
Im thinking it may just be the lenses, i believe they are audi Valeo lens
Old Oct 11, 2009 | 03:48 AM
TSoprano's Avatar
The return rod should be down.. Hopefully that's the problem cause somethings outa whack with your cutoff.. There's a bunch of things that can could cause that. More info on you retro needed..
BTW your car looks nice and clean..
Old Oct 11, 2009 | 06:05 AM
LLZuB's Avatar
Thanks man,
Im pretty sure the bulbs are in upside down then, ill flip them around and see if it fixes the cutoff, I was actually pretty disappointed when I first saw the cutoff because I was expecting it to be better than that lol
Old Oct 13, 2009 | 12:57 PM
petro2342's Avatar
Ever find out the problem?
What projector is that btw? Seems like it could use a clear lense.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
kjlouis
Sep 14, 2015 11:22 AM
