Another Strange Hard Starting Problem... Possibly ECU???
Old Oct 12, 2009 | 03:35 PM
maxtuner96's Avatar
My 96 SE 5spd is now hard to start! It sat for 3 months waiting for the transmission to be rebuilt. Once that was done it was hard to start. I drove it like that for 2 weeks. Each time I would try to start it would either take a few tries....a few minutes...or 10-20 minutes to get started. The Alternator went bad. Replaced it. Still hard to start. The shop I took it to can't find the cause of the hard starting problem yet. Suggesting it is the ECU. When the alternator was going out it may have f'd it up. Anyone have the same problem with the same fix? Or do you have suggestions on what to do?
Old Oct 12, 2009 | 04:13 PM
maxtuner96's Avatar
Also... It does crank. The starter sounds strong and the battery and alternator are both new. But still all it does is crank. I smell fuel after a few tries. It even sounds like its turning over but dies immediately. When It does get started it drives perfect. Smooth acceleration.. switches through gears fine. No problem.
Hopefully we can get to the bottom of this in the next day or so.
Old Oct 12, 2009 | 06:34 PM
pmohr's Avatar
No more Maximas...
So why does it not start? No fuel? Spark?
Old Oct 12, 2009 | 06:46 PM
maxtuner96's Avatar
That's what Im trying to figure out...
Old Oct 12, 2009 | 06:49 PM
pmohr's Avatar
No more Maximas...
So are you saying that you've not checked for spark or fuel, two of the most crucial diagnostics for a no-start issue?
Old Oct 12, 2009 | 06:53 PM
maxtuner96's Avatar
No...That's been checked. Its at the shop now. They checked spark, fuel, compression,...injectors... Everything seems to be working.
Old Oct 12, 2009 | 06:57 PM
maxtuner96's Avatar
They are saying "MAYBE" Its the ECU. But, not certain. Im trying not to buy one and find out that wasn't the problem.
Old Oct 12, 2009 | 06:58 PM
pmohr's Avatar
No more Maximas...
If it's at the shop, and you can't do your own diagnostics or look at the car, then we can't be of much help.
So again, it is getting spark, and the injectors are being pulsed while it's cranking? Does it have fuel pressure, or is fuel being assumed due to the injectors being activated?
How do the signals from both CKPS' and the CPS look? Checked the wiring and reference voltages for them?
And, of course...codes?
Old Oct 12, 2009 | 07:04 PM
maxtuner96's Avatar
Tomorrow I will call and write down the specific details on everything thing they checked. I do remember them telling me they checked the injectors, did the compression test...fuel pump. There are a couple of codes. Of course the knock sensor (I refuse to replace that again) and something about EVAP...not sure exactly. But those two codes have been in there for over a year already and haven't had any problems from them. And again... when the car starts up it runs and idles perfect.
Old Oct 12, 2009 | 07:12 PM
maxtuner96's Avatar
I did notice there was a TSB in the stickies for this. 96-032 (engine cranks, but wont start). Id like to be able to see the details on that and what the solution was.
Old Oct 12, 2009 | 07:19 PM
pmohr's Avatar
No more Maximas...
That TSB concerns nothing more than checking base idle and ignition timing. The procedure must be performed with the engine running, so it's not possible here.
sctludwig
Sep 1, 2022 01:32 PM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
