help with gas millage
Old Oct 19, 2009 | 09:33 AM
jav24's Avatar
i have a 96 gxe and it started wasting too much gas these days and i change the spark plugs and change the oil 2 weeks ago also change air filter, is there something else that im missing that will improve my gas millage?
Old Oct 19, 2009 | 09:37 AM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
what kind of mileage are you getting?
Old Oct 19, 2009 | 09:41 AM
By the way, some threads you could read:
http://forums.maxima.org/4th-generat...s-mileage.html
http://forums.maxima.org/4th-generat...-possible.html
http://forums.maxima.org/4th-generat...ys-gettin.html
Old Oct 19, 2009 | 09:49 AM
jav24's Avatar
i have a 152000 miles on it and im getting 17 mpg i use to get like 22 mpg
Old Oct 19, 2009 | 10:02 AM
nismomaxgtr18's Avatar
I have a 98 Maxima and I used to get 16-17 mpg. I switched over to the 95 ecu and got a Walbro fuel pump and now been consistently getting 19-21 mpg. Driving style has stayed the same.
Old Oct 19, 2009 | 10:14 AM
Coolsaber57's Avatar
Any CELs? Changed Knock sensor? Fuel filter?
Old Oct 19, 2009 | 10:56 AM
aackshun's Avatar
Clean the MAF and TB while you're at it... and @ your mileage I hope you're puttin in the good stuff and not 87.
Old Oct 19, 2009 | 11:25 AM
AEMAXIMA01's Avatar
Are your tires inflated properly? Are you lugging around a bunch of unnecessary stuff in your car? So the spark plugs didn't change anything? Which ones did you put in? I'm going to need to replace mine soon.
Old Oct 19, 2009 | 11:37 AM
burgundyblues66's Avatar
i get around 24mpgs and i have a pretty heavy foot on the gas.
with good gas, 5 spd, new air filter and oil, it should be at least 22ish
Old Oct 19, 2009 | 01:12 PM
jav24's Avatar
i would like to clean the MAF and the TB but i dont know where they are located if someone has some pictures or a link to see them , also i havent change the knock sensor and the fuel filter .
Old Oct 19, 2009 | 01:31 PM
Leo_Koneval's Avatar
Not sure if you have done this yet, but I switched over to Synthetic and my mileage improved, I am going with 22 MPG with a dead knock sensor, with same fuel filter, air filter, ect.
But just like what the other members said above if you are pushing 17 you might need to check the:
-Knock sensor
-Air pressure in tires
-Extra weight in trunk
-Throttle body
-Air filter
-Fuel filter
-Oil (Maybe?)
-Spark plugs (Maybe?)
Haha some of those things seem to contradict each other, like wouldn't a clogged air filter mean less air which equals less gas consumption???? Maybe I am over thinking it
Old Oct 19, 2009 | 03:46 PM
mahanddeem's Avatar
-Knock sensor
-Throttle body
-Air filter
-Fuel filter
-Oil (Maybe?)
how much milage when you switched to synthetic ? many don't like to switch if you car has high milage..
Old Oct 19, 2009 | 07:44 PM
NevadaJack_9's Avatar
Use high octane fuel, check tire pressure, change oil, and keep your foot off the gas. The Maxima is not a Prius, it was never designed to be a gas saver.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
