6th gen brake upgrade for 4th gen??
Old Oct 20, 2009 | 10:43 AM
kevinoseguera99's Avatar
well i have seen that for the 5th gen maximas you can take the bigger brakes off the 6th gen and put them on the 5th gen without too many problems. so im wondering if this ca be done for the 4th gen max?
Old Oct 20, 2009 | 11:15 AM
JNCoRacer's Avatar
Just the tip.
Jeff92SE was selling the adapter brackets for this swap a while back. Not sure if he is anymore.
Old Oct 20, 2009 | 11:35 AM
i kind of thought though that you just need to enlarge the wholes in the 4th gen steering knuckles so we can fit the 6th gen caliper bracket, then the caliper, rotor and pads?
Old Oct 20, 2009 | 11:57 AM
JNCoRacer's Avatar
Just the tip.
Did some searching and it looks like youre right. The holes need to be drilled out from 12mm to 14mm.
Here's the thread I found on it. http://forums.maxima.org/advanced-su...s-4th-gen.html
Old Oct 20, 2009 | 12:19 PM
i thought so, just like the 5th gen upgrade, but for some reason i didnt know before, Thanks. now to upgrade!!!!
Old Oct 20, 2009 | 12:22 PM
JNCoRacer's Avatar
Just the tip.
Where are you getting the parts from? I've contemplated bigger brakes for a little while now.
Old Oct 20, 2009 | 09:06 PM
HandsonMaxima.'s Avatar
i thought of this awhile ago when lurking the 5th gen forums about swapping the 6th gen brakes....4th gens to 5.5 gens= success..5.5gens to 6th gens...=4th to 6th..
what kind of clearance would you need on these?
my mille migila wheels have 37mm offset and are 16', would this be enough or should i stick to some 5.5 gens?
EDIT; duh i would need 17's, dont know why i asked...
Old Oct 21, 2009 | 10:20 AM
i got a friend who works at a junk yard and can hook me up with the parts off another max if they get some, which they do pretty often. and yea you will probably need bigger wheels if your doing the 6th gen brake upgrade, it even talks about it in the link here. .
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Lowered_a33
Aug 24, 2015 04:35 AM
criminalslang810
Aug 9, 2015 03:35 PM
