Loose TC cover bolts?
Old Oct 25, 2009 | 12:20 PM
ATTappman's Avatar
While looking for the source of oil that's been oozing down the left front of my engine, just above the alternator, I discovered this:
Two timing chain cover bolts (7 and 9 in the tightening sequence) were unscrewed pretty far. I screwed them back in and torqued them to spec. I don't know how they got loose.
Has anybody ever seen this happen before? Could they have vibrated loose like that? I know I never touched them, and I've never had a mechanic do anything in that area.
Furthermore, is that stud just below the rightmost circled bolt, the one just above the radiator hose, supposed to have a nut on it?
Old Oct 26, 2009 | 04:01 PM
smai555's Avatar
i would guess somneone did a home timing belt change didnt tourqe it to spec and forgot to put the missing nut back on
Old Oct 27, 2009 | 07:20 PM
pmohr's Avatar
No more Maximas...
Timing belt?
OP: It's extremely unlikely they loosened themselves that far.
The stud appears to be where the upper alternator mounting bolt should be; it should be a bolt, not a stud. Either way, an empty stud should usually have a nut, yes.
Old Oct 27, 2009 | 08:22 PM
maxfever1987's Avatar
those things have been tampered with, its an impossibility. a botl which retains the front license plate doesnt come loose not matter if you hit a pothole or someone rips off your license plate the bolt remains in, so i cant believe it loosened itself
Old Oct 28, 2009 | 03:32 PM
smai555's Avatar
Originally Posted by pmohr
Timing belt?
sorry timing chain im still used to speaking in terms of hondas
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
jonreidhead
Jan 6, 2016 09:38 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
