ever since 9007 mod....
Old Oct 25, 2009 | 06:26 PM
99SEL4ME's Avatar
Hi boys, ever since I did the 9007 mod, I've been getting flashed the high beams occasionally. I think with the different beam pattern, I need to aim them down a bit. I did look in the " How To" section, but couldn't find how to aim them down a tad. I think it's one of the long screw things you turn to adjust. But which one aims up and down and which one aims left and right? Thanks in advance for the quick answer.
Jeff
Old Oct 25, 2009 | 06:28 PM
shadyonedeath's Avatar
why dont u test them out? You're beams are jacked up already, not like you're going to "mis-align" them.
Old Oct 25, 2009 | 06:46 PM
99SEL4ME's Avatar
Hi, well I have been testing them out for a week now and I'm getting flashed by oncoming traffic. The different beam pattern must be higher. The light is much better, but don't want to blind anyone.
Old Oct 25, 2009 | 07:24 PM
No, what I mean is you should experiment which ***** controls left and right and which one controls up and down.
Old Oct 25, 2009 | 08:10 PM
max ride 41's Avatar
cmon man, really??? how hard is it??? only you can prevent max-tard-ness
Old Oct 25, 2009 | 08:38 PM
manny097's Avatar
Parked in front of a wall or garage and try to aim
but good luck bro, i don't think aiming the beam pattern what's wrong
its that freaking glare, its like all this idiot's with HID kits and no projectors
Old Oct 26, 2009 | 07:46 AM
sicivic89's Avatar
When I did the 9007 on my max, I had to aim the headlights down a tad. They were aimed up a bit because of the different bulbs. Shine the lights at a wall straight on when you are parked about 20-30 feet away and use the adjusters to aim them down a bit.
Old Oct 26, 2009 | 12:35 PM
99SEL4ME's Avatar
Update: I went to the place I get my inspection sticker and he told me to pull into the inspection bay and line up the lights on the board. From what he told me, they're exactly where they should be to the inch. He said that the occasional flashing I'm getting from on coming traffic is probably because they're bright, not because they're out of alignment. So I guess these fart knockers who are flashing me are just gonna have to deal, because there are a lot more brighter and blinding headlights out there compared to my 9007's.
Old Oct 26, 2009 | 12:57 PM
Coolsaber57's Avatar
Been a LONG time since I've heard that phrase.
Old Oct 26, 2009 | 05:54 PM
Nopike's Avatar
I tried this modification. Although many will say otherwise, the beam pattern from the 9007 is not suitable for the 4th gen housing, it was designed for a 9004 headlight.
Old Oct 26, 2009 | 07:06 PM
x X CLoud X x's Avatar
did you find out which screw aims the Headlights Downwards?
Old Oct 26, 2009 | 07:58 PM
i don't know wtf you're talking about the the beam pattern is the SAME. You're not changing the reflective housing, you're just amping up the light output.
I don't have a problem with my head lights. I did have to lower them a bit, but i never get flashed or complaints, even when driving behind friends.
Old Oct 26, 2009 | 08:38 PM
tyler5619's Avatar
orientation of the filaments, my son.
Old Oct 27, 2009 | 05:35 AM
queenambeach's Avatar
You can't be wrong and strong at the same time.
Old Oct 27, 2009 | 07:10 AM
njmaxseltd's Avatar
To the OP, the reason your getting flashed is because of the glare or scattered light that makes your lights appear brighter to YOU but also shines in on comming traffic's line of sight. In fact you are causing a hazard to other drivers on the road.
The 9007 conversion put the light output axis 90 degrees off, which distroys the already poor beam pattern of your headlights.
Old Oct 28, 2009 | 12:35 PM
99SEL4ME's Avatar
Hey, I've dinking with those adjustment screws to see which way to aim them down a bit and they won't move. It appears I can use a philips screwdriver or a wrench?
Old Oct 28, 2009 | 01:49 PM
9 or 10 mm socket.
Old Oct 28, 2009 | 02:20 PM
ColombianMax's Avatar
9 or 10 mm socket.
Its either 8mm or 10mm last I checked
Old Oct 28, 2009 | 02:25 PM
99SEL4ME's Avatar
9 or 10 mm socket.
Hi, I got it. I just aimed them down a bit. I will go for a drive soon when its dark and check the aim on the road.
Thanks for your help, I wasn't looking at the correct adjustment screw. Duh!!
Loe max
32
Jan 6, 2005 12:58 AM
diesel9119
Dec 30, 2003 10:10 AM
diesel9119
Dec 28, 2003 11:29 AM
