converting 9007 to 9004 socket? possible?
converting 9007 to 9004 headlight? possible?
i posted this on the electronics section, but just wanted to see if anyone here had any input...
anyone know if this is possible?
I just got rid of the max (got company car) - I have a HID kit for 9004 lights, but my company vehicle has 9007 bulbs... anyone know if there is a way to convert the 9007 harness to a 9004 so that I can run my HID kit?
by the way... I believe the difference is one pin on the harness -- (2 pins on the 9004 and 3 on the 9007)
any help would be appreciated!
thanks,
Randy
thanks,
Randy
Originally Posted by turdlett
Is it possible to change the harness for the light. By this I mean changing the 9007 harnesses for 9004 harnesses.
-a way to convert/modify the 9007 socket to accept the 9004 harness?
-a harness available to change the 9007 socket to fit 9004 setups?
etc....
all i know at this point, is that the base of the 9004 and the 9007 bulbs look similar, except for the fact that there are 2 pins in the 9004 base/bulb and 3 in the 9007 base/bulb... when the 9004 bulb is 'locked-in' to the 9007 socket, nothing works...
What people do with the E36 healight conversions for the 3rd gens are probably using stock wiring just do a little splicing here and there to make the 9005 and 9006 lights work. They could also just change the wiring from the relay all the way to the headlights. You may just have to do that.
i really would love to be able to still use the kit... otherwise, i'm not sure what i'm going to do with it!
thanks for the input Turdlett
-Randy
Originally Posted by Maxima10to1
the 2 sockets are the same. the only difference is which of the 3 wires does what. One is a ground, one is low beam, and the last is high beam. all you have to do is rewire them.
thanks!
Originally Posted by MaxedOutOfCash
i converted from 9004 to h4 without any major modifications, so you should be able to do this too. . . take your time and you'll figure it out...
i'm all set...
thanks for the replies
-Randy
Originally Posted by Fosgate Fan
how's the beam pattern? think the filaments are different on 9004 and 9007s
ivorton23
Sep 28, 2015 09:08 PM
carid
Sep 9, 2015 05:06 AM
