what is this part
Old Oct 26, 2009 | 05:19 PM
smai555's Avatar
what is this part
circled in red at the top
it sounds like its grinding when i turn the key to "run" and when i turn the key to "off"
oh i also have the starting problem that seems to effect a lot of cars so i was thinking that part might have something to do with it
thanks
guys
Old Oct 26, 2009 | 05:22 PM
ATTappman's Avatar
EVAP purge volume control valve.
Old Oct 26, 2009 | 05:25 PM
smai555's Avatar
thanks for the quick reply
does anyone else sound like its grinding when you turn the car to run (but not starting) then turn the key to off and it makes the same sound?
thanks
Old Oct 26, 2009 | 09:38 PM
HandsonMaxima.'s Avatar
you mean that sound of a spinning object sliding into place underwater when you turn your key to on, completely normal, mine does it to.
Sorry to thread jack! but what is that object with 2 hoses covered in silver called? mines leaking up a storm and i cant find it in the FSM
also nice engine
Old Oct 26, 2009 | 09:43 PM
Originally Posted by smai555
oh i also have the starting problem that seems to effect a lot of cars so i was thinking that part might have something to do with it.
What's the starting problem? Cause when its cold out I have to step on the gas a little while starting the car or else it stalls out. I know I have an EGR code and an EVAP code and I'm wondering if we're having the same problem.
Old Oct 26, 2009 | 09:44 PM
Feldman's Avatar
also nice engine
What are they leaking?
I think they are the coolant lines to your heater core
Old Oct 26, 2009 | 09:47 PM
defiance's Avatar
What is the EVAP purge volume control valve function ?/
Whats happens when if its bad ?
Old Oct 26, 2009 | 09:54 PM
anomaly117's Avatar
thanks
i know my max makes a sound after making this cycle, and i always assumed it was my VI
Old Oct 26, 2009 | 10:39 PM
my Vi makes a PSHh sound when i turn my key on.
as for what they are leaking i dont have a clue, i have a PS leak ive been chasing since i got the car, my coolant stays pretty much full, i keep having to refill it because i keep messing with my lines so idk. and i have a slight oil leak either in the engine or right there.
i cant tell by smell because when i redid ALL of the PS lines some of it spilled out the resi and happen to fall all over that area. i cant tell by look because it looks the exact same as the old PS leak in front of my radi, but is black and grimy.
maybe its my blinker fluid?
and if your evap breaks, you, get a code lol. most people bypass in their 00vi swaps.
Old Oct 26, 2009 | 10:42 PM
smai555's Avatar
also nice engine
yea i believe its coolant lines for the heater core
this isnt my engine i stole the picture
"What's the starting problem? Cause when its cold out I have to step on the gas a little while starting the car or else it stalls out. I know I have an EGR code and an EVAP code and I'm wondering if we're having the same problem."
i have no codes... my starting problem is it will never start on the 1st try and almost always will fire on the 2nd i have been battling this starting problem for almost a year ... i did the grounding mod/trick and changed the ECTS and it worked for 1 week and it was back
Old Oct 26, 2009 | 11:23 PM
well your problem is directly related to your starter switch, your other thread pretty much, the contact points get wore down ect, that is the root of your starting problem my friend. i would bet on it.
does your car just" do nothing" when your turn it all the way to start it? then immediately flick back to "on" then when you try to start it again it starts up like a rocket? if so, starter switch, its what mine did.
also chrisman, i think your IACV is going out, sounds just like min did on its way out the door, especially now that its getting colder.
Old Oct 27, 2009 | 09:59 AM
smai555's Avatar
no the 1st time i turn the key it will crank but not start then the 2nd time it will start either normally like id expect it to or BARELY (not like a rocket at all)
either way im going to get a new switch and try it if it doest work ill return it
Old Oct 27, 2009 | 12:46 PM
did you manage to get your old switch rebuilt??
you could just do what i had to do to test drive a datsun
hotwire it!
Old Oct 27, 2009 | 12:52 PM
smai555's Avatar
yea and i got a new one to see if the starting problem was the switch .... same thing cranks, no start, on 1st try.... fires up on 2nd
i just asked this on a another thread but ill ask here too
does your CEL turn off before you turn your key to start ?
Old Oct 27, 2009 | 01:25 PM
smai555's Avatar
STARTING PROBLEM FIXED!!!!!!
took out the CKPS (POS) had a big chunk of metal on it cleaned it off now the car starts everytime
thanks
everyone
Old Oct 27, 2009 | 01:34 PM
NISSANMAXIMA91's Avatar
Power Steering lines fellas. . .
Old Oct 27, 2009 | 01:55 PM
modenaf1's Avatar
Just curious, why do people bypass EVAP when they swap? I was running mine bypassed when I swapped and for some reason the car hated it. I reconnected my EVAP and it hated it even more for about 5 minutes then all the stuttering problems cleared up.
Also, what is there on the 00vi that could make a sound when you turn the key on? I have an 01 intake too and the only source of power that the manifold itself gets is after it hits 5000RPM from the wire that is connected to my VAFC II.
Old Oct 27, 2009 | 01:58 PM
smai555's Avatar
yes another look and i concur
Old Oct 27, 2009 | 09:18 PM
Great to hear!, ill have to pull mine and make sure mine isent getting bad.
well now that kind of makes more sense guys! i examined it more closely today and i discovered, its grease! from a blown apart boot from the last owner. and PS fluid covering it. god knows how i will fix it, i cant even get my PS pully to move so i can change the belt.
its not quite a sound, its just it opening.
well, mine makes a noise because of my switch, its set to open @ 600rpm and close @ 4600rpm, so when i start the car, pshh.
5000rpm? nice power band you got there!
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
