Kyb gr2 and Progress Springs
Old Oct 30, 2009 | 07:33 PM
montwalker2001's Avatar
Will the Kyb gr2s hold up on Progress Springs
Old Oct 30, 2009 | 07:37 PM
They'll hold up for a bit since that's a little more than a mild drop but don't expect them to last forever. GR2's are like a stock replacement.
Get some AGX's or Illumina's.
Old Oct 30, 2009 | 08:02 PM
Ok Thanks
Old Oct 30, 2009 | 08:21 PM
maximized98's Avatar
Addicted to the Org
I have been using this setup for about a year and a half with no problems. The ride is great.
Old Oct 31, 2009 | 04:05 AM
max ride 41's Avatar
i have gr2's and maxspeed springs, 1.5 front, 1.3 rears with no issues. gr2's are def better than stock, chris is nutso...
Old Oct 31, 2009 | 07:00 PM
BORQUA79's Avatar
nycmaximas member
Cattman suggest that setup... I would trust a name like that....
Old Oct 31, 2009 | 11:05 PM
Coolsaber57's Avatar
They are more of a stock replacement...just like Tokico blues.
They aren't recommended for drops of more than 1.5". Yes it'll work, but in the long run you'll wish you had sprung (no pun intended) for better struts.
Old Nov 1, 2009 | 03:25 PM
RA030726's Avatar
I'm nutty for Nissans
Youll bottom out all day long.
Old Nov 1, 2009 | 07:13 PM
nodora97's Avatar
Perfect setup!
Old Nov 1, 2009 | 07:49 PM
And people think I'm crazy...
Old Nov 2, 2009 | 06:50 AM
I believe the term was "nutso"
Old Nov 2, 2009 | 08:14 AM
Oh yeah...
Old Nov 2, 2009 | 01:49 PM
Quickywd01's Avatar
I just installed kyb gr2's and eibach pro kit. 1.5" front drop and 1.3" rear. The rear is fine but the front feels like crap. Feels like it's bottoming out on everything. Maybe I didn't cut the bump-stops enough? Other than that the handling is pretty good and with pilot sport plus tires it's a good amount of grip for the street.
Old Nov 2, 2009 | 02:00 PM
as long as you cut the top bump, section, you should be fine. i have the same drop and it'll take awhile for the springs to settle and the drop to feel right.
Old Nov 2, 2009 | 02:03 PM
i never had a problem with the gr2's at all. and they're def better than stock. i blew out the stock rears i replaced in a little over a year and the ride was really no better. i've had the gr2's for 2 years and the rides alot better than the stock ever was.
Old Nov 2, 2009 | 02:28 PM
Quickywd01's Avatar
It's been two months. How much bump stop should be left after cutting?
Old Nov 2, 2009 | 05:41 PM
lol what??? all of it except top bump. you should've only cut the top 1
Old Nov 2, 2009 | 06:25 PM
Quickywd01's Avatar
I cut 1.5 ribs of the skinny side. I knew I needed to cut more but that's what happens when you have other people standing around pretending they know what they are doing. I'm going to take the fronts apart again and cut off more bump-stop. So you're saying cut everything off except the last/biggest part of the bump stop?
Old Nov 2, 2009 | 06:53 PM
AnGel MaX's Avatar
bro go wit the kyb agx, i hit gas on turns
Old Nov 2, 2009 | 07:07 PM
Quickywd01's Avatar
I only cut the bottom (between 2&3) or the bottom and half of the next one. I was supposed to cut from 3 to 1? I've got to rent the spring compressor and fix this asap!
Old Nov 2, 2009 | 07:29 PM
Addicted to the Org
You don't need to get spring compressors to cut those. Just get a knife, that's what I did.
yo, the guy that installed my suspension will tell you for sure. his org name is djfrestyl, pm him. he does these all the time and will tell you for sure. i think he only cut the 1.0 top bump on the skinny end.
Old Nov 2, 2009 | 08:13 PM
QFT.
I can't wait to put my AGX's/Eibach's on. Gotta get my KYB dust boots first and wait till spring. I should have my RSB by then as well. Handling is going to be .
Old Nov 2, 2009 | 08:51 PM
RA030726's Avatar
QFT.
Its a bad setup. Its either bouncy or as rough as it gets.
Old Nov 2, 2009 | 09:05 PM
It can't be that bad. I've read that with the struts set to 3F/6R it's actually pretty good with Eibach's.
Old Nov 3, 2009 | 03:51 PM
RA030726's Avatar
No its crap. You couldnt pay me to run AGX again. They are the worst strut for the money.
Old Nov 3, 2009 | 06:49 PM
njmaxseltd's Avatar
They are kind of stiff. Actually even the GR2's are pretty stiff.
I found the AGX's to be OK on the stock springs the first year I had them. Winters are tough on them, the ride goes down hill as the temp goes down. After about 20K miles I couldn't get them to ride nice no matter what setting I used. They just lost there ability to absorb bumps and the ride became pretty harsh. I run GR2's in my Explorer and the ride is definately very firm. They handle nice, but they don't ride very smooth. The best riding strut, hands down are the Illuminas. Rode them for years, put almost 100K on a set.
Best stock replacement for your buck, Monroe Matics or the Sensatracks. For under 200 bucks (with a coupon) you can put 4 new dampers on a stock Max. The Sensatracks will run you a bit more.
They both ride firm, yet absorb bumbs nicely and definately handle better then the softer riding Tokico Blues.
My .02 cents..
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
