where to buy/part number trans seal
Old Nov 2, 2009 | 04:52 PM
ls1forlife's Avatar
Does anyone know the part # for the drives side trans seal on a 95 5spd non lsd transmission? Mine is leaking and i need to get one. Autozone doesnt have a part listing for it either.
Thank you
Old Nov 2, 2009 | 06:20 PM
pmohr's Avatar
No more Maximas...
Assuming you mean the axle seal, it's 38342-03E00, $7.52 @ Courtesy.
Autozone has it, Timken PN 710118.
Old Nov 2, 2009 | 06:33 PM
Quickywd01's Avatar
That autozone part number says it's for the automatic. Are they interchangeable?
Old Nov 2, 2009 | 06:36 PM
pmohr's Avatar
No more Maximas...
The part number I listed should work just fine for the 5MT, driver's side.
Old Nov 3, 2009 | 06:22 AM
ls1forlife's Avatar
Yes I mean axle seal, that autozone part # says transmission seal. But yes, i need the axle seal. It does say for automatic, so I will go with the courtesy p#.
Thank you agian.
Old Nov 3, 2009 | 07:48 AM
njmaxseltd's Avatar
Check for play in the axle before you waste your money on that seal. Usually when they start to leak, it's a pretty good indication that your diff. bearings are worn.
A very common issue with the 5MT trannys. Replacing the seal usually doesn't fix the leak.
Old Nov 3, 2009 | 08:05 AM
ls1forlife's Avatar
I didnt think the seals were the same from manual to automatic? why wouldnt parts places state that?
thanks for all the help
already checked. thank you
should be the same, but for mine (99 5MT) its oil seal part number 18000 (from canada anyways) and the diameter is 3.558 inches
all the same thing i guess, trying to seal the trans up from leaking out the lubricant. but i think most of the Canadian cars are lsd. mine is not for sure
Old Nov 3, 2009 | 05:32 PM
pmohr's Avatar
No more Maximas...
The part number doesn't mean anything without a manufacturer. Also, assuming you've got the original trans in your car (and it was originally destined for Canada) then you've got a VLSD, which has a different seal.
Originally Posted by Timken's Catalog
Originally Posted by Rock Auto
Originally Posted by Advance Auto Parts
Old Nov 3, 2009 | 06:27 PM
ls1forlife's Avatar
Thank you so much, im going to Advanced auto tomorrow and ordering the part part. I do NOT have the LSD
Old Nov 3, 2009 | 09:20 PM
Pyrex42's Avatar
Not all canadian maximas are lsd. mine isn't. the only place to get seals up here is the dealer. like $10-20
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
mpbclutch33
Dec 26, 2015 11:11 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Oct 4, 2015 08:43 AM
