Advice needed on replacing the car radio
Old Nov 3, 2009 | 06:54 AM
Justaguy's Avatar
Hi,
My 98 Maxima factory car radio is dying (volume control not working, cd gets stuck often, etc). It's also a tape and CD player.
Looks like this:
http://www.carstereohelp.com/images/nissan1.jpg
Can I upgrade to a DVD and CD player? (Meaning a DVD that has mp3 format for music), and get rid of the tape deck as I no longer listen to Barry Manalow
Would that would fit nicely?
If I bought the same radio that I have now, is it a simple installation?
I see ebay has the same radio for about $100, but maybe if a few more bucks I can upgrade to mp3 player.
Thanks for the suggestions
Old Nov 3, 2009 | 07:44 AM
njmaxseltd's Avatar
YOu sure it's BOSE? If not, I have a perfect non BOSE unit I can let you have really cheap!
Old Nov 3, 2009 | 08:16 AM
oldngivout's Avatar
Willing to learn
If you have the BOSE system, then this is what you need for MP3 playback with a factory appearance.
http://forums.maxima.org/infiniti-i3...tall-pics.html
Old Nov 3, 2009 | 08:34 AM
cashoit's Avatar
U can install any aftermarket radio/dvd system u want. There is plenty of space in the dash
Get the Factory service manual or the Haynes manual. It will show u how to replace the radio
Old Nov 3, 2009 | 08:47 AM
maxirob's Avatar
My 97 had the Blows, ur I mean Bose CD/Tape/Radio in it-same prob-volume control developed a mind of it's own. I replaced it with a 2 DIN DVD/CD/MP3 player. Had to mod the factory radio brackets that hold the stock radio to mate with the mounting on the new unit. I also picked up a factory wire harness at WallyMart, unplugged the Bose Speaker Amps and wired directly to new Infinity Speakers. I used 6.5" coaxials in the rear and 6.5" Components in the front-popped off the factory tweeter grills and carefully modded to fit the Infinity Tweets-turned out NICE and sounds every bit as good as the Better Off with Something Else stock system. In fact i used the plastic housings in the front doors for the Infinity X-overs. You will also need an antenna adapter-available at WallyMart also.
Old Nov 3, 2009 | 08:53 AM
96nismoSE's Avatar
+1 on the pathfinder 6-disc! i bought mine not to long ago and love it!!
Old Nov 3, 2009 | 09:03 AM
Justaguy's Avatar
Actually it's not a bosh, but it does look like that pic.
On the Tape cover it says
"Full Logic Deck Auto Metal cn585 Dolby b NR"
njmaxseltd: how old is that radio? Have any pics?..send me a pm for price, I might be interested if the mp3 price is out of reach.
Thanks!
Old Nov 3, 2009 | 09:08 AM
Justaguy's Avatar
maxirob: Which 2 DIN DVD/CD/MP3 did you buy? Doesn't the drive gear get in the way when opening those 2 DIN players?
Old Nov 3, 2009 | 10:23 AM
maxirob's Avatar
It's a valor ngw-670 I think. No problem with clearance when open. Sounds like you don't have the BLOWS unit- so all you have to do is get a wire harness and antenna adapter and mod the backets and you be jammin'
Old Nov 3, 2009 | 11:04 AM
NevadaJack_9's Avatar
Go to crutchfield.com if you want an aftermarket unit. Great service, and prices
Old Nov 3, 2009 | 03:50 PM
Q8BallMAXIMA's Avatar
Diddo on the door mod for the tweets. I did the same thing in my max! Infinity tweet I put in look almost as if they came from the factory.
Old Mar 16, 2010 | 08:12 PM
knowskills's Avatar
I agree Crutchfiled has lots of information about getting a nice aftermaket stero
Old Mar 18, 2010 | 02:03 PM
jonnypax09's Avatar
You could really put any radio you want in there single din if you wanted to keep the pocket, and double din if you wanted to get rid of the pocket and put in a nice 7" screen. Not hard to wire up either so you could save yourself some money by doing it yourself and put it towards the radio. I'de suggest aftermarket and like the rest are saying, crutchfield has a huge selection but sometimes expensive, depends on how much your trying to spend.
Old Mar 18, 2010 | 02:38 PM
ampire's Avatar
If you do get a different radio, I recommend running 16-18awg speaker wire to all your speakers rather than simply using the factory wiring. It makes everything much less of a hassle in the future. Its not too hard to get the wires into the doors.
I put heatshrink tubing on the speaker wire after passing it out of the cabin's rubber hole and into the rubber on the door, ziptied it to the factory wire bundle, it looks factory but it makes aftermarket speakers a lot less of a hassle (don't have to use the puny factory wire).
Old Mar 19, 2010 | 12:04 PM
jinkst1's Avatar
I also have a 98 maxima with the bose head unit - it has also been acting up. I tried to install a sony head unit, but left the bose speakers. I got no power to the new sony head unit, it didn't turn on. Is this because the system will only work with a bose head unit?
Old Mar 19, 2010 | 12:13 PM
Fasteddie01's Avatar
TO Jinkst1 : Look at the Forum listing for Maintenance ... - there's a section for Audio & Electronics whole lot of instructions and Q&As about replacing Bose. You prob need an adapter harness, and the speakers need to be replaced cause they're amplified. Look it all up ... since I don't have Bose, I can't give you details.
Old Mar 20, 2010 | 04:30 PM
VTonmymind's Avatar
Mmm, fresh lobster
Uh, why not head over the the audio forum and have those those guys hook u up as I wouldn't do anything but install an aftermarket set up, Bose be damned.
Lakersallday24
Jun 16, 2019 01:35 AM
Maxilano
Aug 31, 2015 07:33 PM
TonyJr
Aug 20, 2015 12:14 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
