Rear Passenger Caliper Needs to be Replaced
Old Nov 3, 2009 | 10:48 AM
Dexter's Avatar
hey guys, I need to replace my rear passenger side brake caliper. I looked in the how-to section and can't find anything on how to go about doing that. Also, my haynes manual got trashed due to a spillage in my trunk. Can anyone point me in the right direction to find instructions on how to replace it? Thanks.
Old Nov 3, 2009 | 03:06 PM
Q8BallMAXIMA's Avatar
It is pretty easy to replace them, there is only 2 bolts and the hose. Be sure to turn in the piston on the caliper to get it back on over the pads. Like I said, you will need to turn clockwise to get the piston in.
Old Nov 3, 2009 | 05:51 PM
Dexter's Avatar
Turn what in? the replacement caliper already has the piston in. I am under the impression that it is just a matter of removing the hose and the caliper, replace the shoes, and mount the new ones + bleed the brakes, is there anything I am missing?
Old Nov 3, 2009 | 05:55 PM
KRRZ350's Avatar
Unclip e-brake.
Unbolt caliper/
Remove caliper & e-brake cable at same time, leave brake hose connected.
Put new caliper & e-brake on (Some times you have to swap stuff, do it now.)
Swap hose from old caliper to new, bleed, reinstall wheel.
Old Nov 3, 2009 | 06:13 PM
Dexter's Avatar
Originally Posted by KRRZ350
Unclip e-brake.
Unbolt caliper/
So I can replace the caliper without dealing with the brake shoes or pad retainers?
Thanks, wish me luck.
Old Nov 4, 2009 | 11:11 AM
Dexter's Avatar
Got the job done, runs like a dream again and best of all no brake fluid leak
Couldn't have done it without you guys.
This site has saved my a$$ once again!
Old Nov 4, 2009 | 11:40 AM
Some rebuilds may not be completely turned....only suggesting that if it is hard to get over the pads again.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
george__
Aug 18, 2015 07:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
