Question for those of you who have done a starter rebuild
Old Nov 4, 2009 | 08:30 PM
RyanTaylorClark's Avatar
I'll try to keep this short and simple. My starter started having issues a few years ago, so I regreased it using the motorvate guide here: http://www.motorvate.ca/mvp.php/516. A few months later, it started acting up again and actually left me stranded. I decided just to buy a new one.
I had a huge problem with a differential oil seal leaking after a tranny rebuild which destroyed my clutchmasters stage 3 clutch and basically turned it into paste. I replaced that and rebuilt the tranny again, but that paste got inside my starter.
Now my newish starter is acting up (from the crap that got inside it) so I decided it was time to clean it out. I removed the starter, cleaned it up, regreased it, and put it back in. Now it won't even turn over. Motorvate seems to be down (who knows how long it's been like this) and so I can't remember exactly where I should grease up. For those of you who have done this, where did you grease? Or more importantly, where should I not grease.
At first, I greased almost every moving part (including the magnets and the brushes at the end) but after it didn't turn over, I wiped these parts clean. It's still not turning over though, so I'm looking for advice. Well, it didn't end up being that short of a post, but any suggestions are still appreciated!
Old Nov 5, 2009 | 07:05 AM
pmohr's Avatar
No more Maximas...
The FSM shows the lubrication points:
Old Nov 5, 2009 | 07:39 AM
You don't know how long I spent searching the forums and google looking for an exploded view of the starter from the FSM. That's exactly what I needed. Thanks pmohr! Maxima.org delivers once again!
Old Nov 5, 2009 | 02:30 PM
f550maranello2's Avatar
ur not supposed to put any grease on the magnets.. just what the pic shows..
also clean the comm, and brushes... you can clean the comm with a pencil eraser.
Old Nov 14, 2009 | 04:20 PM
atriuum's Avatar
What is the comm? I don't see it on the starter diagram above.
Old Nov 14, 2009 | 06:21 PM
Nozama's Avatar
Grumpy old guy
The end of the armature that contacts the brushes.
Old Nov 15, 2009 | 08:15 PM
yep its the part of the rotor that makes contact with the brushes..
make sure its clean and not terribly worn out.. if its dirty clean it with a pencil eraser..
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
msellas
Sep 23, 2015 09:16 PM
