windows, auto up and down
Old Nov 7, 2009 | 04:48 PM
smai555's Avatar
im sure its possible but at what expense? just a switch or a whole circuit of switches, plugs, control modules, relays, timers, beepers, blinkers, etc..etc..
what do u think?
Old Nov 7, 2009 | 09:37 PM
JtzMax's Avatar
Whatchyou say?
Could be done I'm sure. I'd say it could be done pretty easy with a relay and a 555 timer circut. You'd have to build a small circut board and wire it up, but yes, it could be done.
Old Nov 7, 2009 | 09:44 PM
EnervinE's Avatar
i has college
I'd be interested to know how the auto down function works, in the first place.
Old Nov 7, 2009 | 09:47 PM
aackshun's Avatar
http://forums.maxima.org/4th-generat...-possible.html
http://forums.maxima.org/4th-generat...n-windows.html
Has anyone done anything similar to what's in those threads?
In for the results/solution. I miss those features from my 5th gen.
Old Nov 7, 2009 | 09:49 PM
RAZ76's Avatar
Mine is factory for both windows, up and down, nice feature.
Old Nov 8, 2009 | 12:08 AM
TLMNICK's Avatar
The DEI 530T does the job nicely. I have one in both my 4th gens, and have no issues. I can operate the two front windows from remote, and I also have the "one-touch" open and close.
One of those modules will control two windows in both directions. If you want to control all 4 doors, then you'll need two modules. I only did the fronts. Make sure whoever does the install KNOWS what their doing. This requires the installer to go into each door to make connections right at the window motor. Also, don't use anything thinner than 16guage wire, or else the windows will move slow.
I've installed many of these modules, and have never had an issue with them.
Old Nov 8, 2009 | 08:16 PM
aackshun's Avatar
Mind installing it on my car ??
If not do you mind doing a write up? or is similar to this RSX...
http://forums.clubrsx.com/showthread.php?t=177722
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
BobTX10
Oct 7, 2015 08:43 AM
