HELP IT WONT START!!
Old Nov 16, 2009 | 11:31 AM
RustyMaxima's Avatar
I recently bought a 96 maxima but everytime i try to start it nothing at all i used my test light and the ignition is sending out the singal but the starter isn't getting it. could my alram be set to starter interrupt if so how do i reset it?
Old Nov 16, 2009 | 05:01 PM
FallenOne's Avatar
What years the Max... Cus if its a 90, your in the wrong forum.
Old Nov 16, 2009 | 06:52 PM
trooplewis's Avatar
has it ever run, or did it just stop starting one day?
Did you do anything to it recently?
Old Nov 16, 2009 | 07:07 PM
maxfever1987's Avatar
try checking the fuse in the fuse box near the drivers knee, theres something called ENG CONT-MEANINF ENGINE CONTROL TRY replacing that one and se what happens
Old Nov 17, 2009 | 11:45 AM
Its a 96 max the ignition was shot so my friend rigged it so we could get it back my garage it got there fine, but then the next day i put a new ignition in it and it wouldn't start at all ( it wasn't turning over) so i went through every thing i knew to fix it i replaced all the fuses and realys for the starter and ECM still nothing. :'(
Old Nov 17, 2009 | 04:23 PM
cherlas-son's Avatar
I need help too. I have a 1997. It started great yesterday morning. Last night I moved it and it was a bit harder to "catch" and start. The starter motor turns fast. It did start and it wouldn't idel really well. Well then this morning the starter motor turns it hard and fats but it doesn't catch. A buddy put his meter on it and to check the codes and it says there was no signalk from the cranck sensor he checdkls the ohms on it and it was off also. I cant get the part till tomorrow but if it ISN'T the crank sensor(s) any ideas what else it could be??
Old Nov 17, 2009 | 05:03 PM
trooplewis's Avatar
Rusty, did you check the Shift Lock on the console?
cherlas, the crank sensor is probably the fix.
Old Nov 18, 2009 | 09:06 AM
No i haven't checked the shift lock yet but ill check it out tonight. but i borrowed the consult computer from my buddy at nissan and it throwing a EL- code i have it at the shop i forgot it. HAve u ever Heard of An EL code????
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
