While my UIM is off
Old Nov 29, 2009 | 02:37 PM
hornepirate's Avatar
While my UIM is off
Is there anything I should check before putting it back together?
also i noticed it was very black in the uim. Is it recomended to clean it?
just curious
Old Nov 29, 2009 | 02:50 PM
Just clean it out.
Old Nov 29, 2009 | 03:48 PM
maxfever1987's Avatar
i sprayed air intake cleaner in mine clean of the egr guide tube, clean inside th uim, clean the iacv and throttle body, once you start your car it will be smoking blue so dont be surprised when you see blue smoke coming out it, if you have more concerns plz ask
Old Nov 29, 2009 | 03:52 PM
trooplewis's Avatar
Why is it off? Did you change out the rear plugs and the rear valve cover gasket? Knock sensor is a lot easier to change with the UIM off...
Old Nov 29, 2009 | 04:01 PM
Originally Posted by trooplewis
Why is it off? Did you change out the rear plugs?...
The UIM doesn't have to be taken off to change the rear plugs.
Old Nov 29, 2009 | 04:38 PM
tyler5619's Avatar
^ yeah, i was WTFing on that one.
Old Nov 29, 2009 | 07:07 PM
Coolsaber57's Avatar
If you haven't already, you could change out your knock sensor....it should be real easy with that off.
Old Nov 29, 2009 | 07:16 PM
manny097's Avatar
replace that small coolant hose in the back, its a pain in the butt to replace
Old Nov 29, 2009 | 07:55 PM
Yeah i need a new coolant hose...one of them snapped into pieces while i was removing the manifold....and i have it removed to change two of my injectors that took a dump on me.
Would Carb/ TB cleaner be fine to clean out the UIM? Yeah Ill prob removed the EGR tube and clean that out too...my IACV has 26k on it..the previous owner changed it and its not too dirty
MY gaskets are all fairly new...i got a new IACV gasket though so ill probably do that
Old Nov 29, 2009 | 08:37 PM
Or SeaFoam.
Old Nov 29, 2009 | 09:14 PM
seafoam is like $8 bucks a can here...i have about 4 spray cans of CRC so ill prob just use that...and a microfiber cloth
tyler5619's Avatar
Or SeaFoam.
good call.
Old Nov 29, 2009 | 09:23 PM
That Deep Creep stuff is a little more expensive, but I like it because it's concentrated. Well worth the money IMO, but if you have cans of CRC fawk it. It should work just as well.
Old Dec 1, 2009 | 08:20 AM
cashoit's Avatar
WHy would it black inside the UIM...jus curious.
Old Dec 1, 2009 | 09:58 AM
trooplewis's Avatar
LOL, I get my Max's and Altima mixed up.
The Altima you have to remove the UIM to replace the rear plugs.
I've done one of the Max's, yeah, no need to take it off for that.
Old Dec 1, 2009 | 04:49 PM
Kico's Avatar
When I took my UIM off it was nasty inside. So I went to the store and bought a can engine D-greaser, went to the self wash and washed the UIM with a pressure washer inside and out till it sparkled in side and out. I all so did valve cover gaskets, cleaned EGR tube, IACV, TB, and replaced knock sensor and PCV valve. It turned out good for me hopefully it turns out good for you and it also made the car run smoother.
Old Dec 1, 2009 | 07:53 PM
i let mine soak with tb cleaner and let it drain out...then dry...then wiped it down and used a dremel tool with a polishing head and polished as much as i could of the upper and lower
Old Dec 2, 2009 | 10:59 AM
cashoit's Avatar
Im all for cleaning the car. But i get nervous when cleaning the engine compartment. I have never done so cuz i dont want to short anything
Old Dec 2, 2009 | 02:07 PM
im talking about cleaning inside the manifold...not the outside....and as for cleaning the compartment...you wont shrot anything out...just put a bag over the abttery, cone filter intake if you have one, and the alternator and hose her down....while shes cold not hot
Old Dec 2, 2009 | 06:31 PM
aackshun's Avatar
Just use rim cleaner + garden hose if you're afraid to goto the quarter wash like I am.
It's not show worthy yet (didn't really wait or did it a second time over), but i've gotten a few "ooh, this car is how old again" comments.
Before:
After:
Finkle
Sep 27, 2015 09:53 PM
MOHFpro90
Jan 14, 2011 05:05 PM
grey99max
Dec 7, 2008 07:20 PM
elcid98
36
Jun 1, 2007 12:19 PM
inspiredbykev
May 20, 2007 12:16 AM
