Problems with my ALT Belt. Squeaking.
Old Dec 1, 2009 | 08:18 PM
TravisCadello's Avatar
I got a 95 Maxima and I've had it for 5 months now and haven't really driven it in rainy weather, But i noticed if i hit a puddle of water in the street my belt will squeak really loud for a few seconds and go away.
Well today is verry bad weather and was lots of water i got 2 blocks away from home and realized the dam reliable *** Max Wasn't gonna get me to where i needed to go. The belt squeaked really loud as soon as i left my house and then didn't make any more noise but all my lights got super dark and never came back up. i let it idle in dry spot for 2 minutes and finnaly the lights got bright again, as soon as i got back on the street they went dark again so i just took the Max Home and parked it.
I checked the belts the other day and they look all new and are good and tite, the power steering works good but the alternator is whats not getting spun in rainy weather.
What could be wrong? Thanks guy's!
Old Dec 2, 2009 | 10:12 AM
Dam, Nobody knows? maybe i should tighten it as bit more? or by some belt dressing?
Old Dec 2, 2009 | 10:22 AM
trooplewis's Avatar
Or do a search, there is probably 50 threads about it...
Sounds like it needs tightened if it is squealing.
If you get brake light + battery light, you need a new alternator.
Old Dec 2, 2009 | 10:26 AM
njmaxseltd's Avatar
Belts glazed?
You sure they're tight?
Alty. pully glazed up?
Alty. spinning freely, bearings ok?
Missing splash shield causing the water to get all over the belts?
It's not rocket science, the belts have to be in good shape, tight, dry and the componets they're connected to must be in good working order as well.
Old Dec 2, 2009 | 10:30 AM
Originally Posted by njmaxseltd
Belts glazed?
I realized their are no splash shields and is the only thing i can think of. do i need those? if so where do i get them at?
Old Dec 2, 2009 | 01:14 PM
njmaxseltd's Avatar
Um, Lets read your first post.
So in answer to your question, YES.
Junk yard? Check the classified ads on here, post a wanted to buy thread. There are lots of guys parting out 4th gens these days. Should pretty easy and cheap to get them 2nd hand on here.
Old Dec 2, 2009 | 05:58 PM
RA021526's Avatar
Keep in mind that the splash shield doesn't really cover the belt completely. If you have no splash guards at all then yeah, get some. You should really try tightening the belts. Maybe loosen then up a bit first so you can check if they're cracked, etc. It might be a good idea to replace them. There's a diagram in the fsm that'll show you what to do (basically), but you can also search. pmohr has a video of changing the belts on youtube. check it out.
Old Dec 2, 2009 | 07:28 PM
i drove a few of my cars with out the splash shields and the belts didn't squeak. ill try in tighten it a bit more and go to junkyard to get new splashshields.
Old Dec 4, 2009 | 05:11 PM
Phantom 309's Avatar
I just replaced alt on my 95 a montha ago and this one has gone out..A reman from Advance Auto..
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
