OEM wheel selections
Hey I have the 06/07/08 7 spoke maxima rims (17 x7) and wanting to move up to 18s. I know the bolt patter is 5 x 4.5 (114.3 mm). Will Mazda's rims fit, hub fitment, offset? Also, I see they went from a 4.5 spacing to 114mm....will 114mm fit on our car?
(may need other members to confirm the following)
several other car's OEM wheels will fit our cars. you need to find wheels with the bolt pattern "EXACTLY 5x114.3", center bore of "AT LEAST 66.1", and offset of between +35 and +45.
keep in mind, though, if the center bore is GREATER than 66.1, you will need hubcentric rings (basically an adapter that resizes the center bore of said rim), or else you will be "lugcentric", which means the wheel is held on by the lugnuts, but not the center. some people don't mind being lugcentric, but it makes me nervous.
IIRC:
most 5-lug mitsubishi wheels have 5x114.3 / 67.1
(for instance, lancer wheels)
most 5-lug mazda wheels have 5x114.3 / 67.1
(for instance, millenia wheels - by the way, very lightweight wheel)
almost all 5-lug nissan/infiniti wheels have 5x114.3 / 66.1
many aftermarket wheels have 5x100 AND 5x114.3, with a 70-something cb, obviously needs centering rings, and sometimes you also need tuner lugs due to the smaller size of the lug hole.
i would stray from anything else.
p.s. there is actually a wheel and tire section. you may get flamed for posting this here lol
IIRC:
personally, i think the sedans are better. i like unidirectional tread patterns, and you can't rotate staggered wheels with unidirectional treads. unless you pay the extra $5-$20 (depending on who you know lol) per tire to have them broken down and re-mounted...
o rly?
o rly?
MILLENIA, 94-on, 15 X 6.5
PROTEGE, 02-on, 14 X 6
RX-7, 93-96, 16 X 8
626, 88-on, 15 X 6
929, 88-on, 15 X 6
MPV, 99-on, 15 X 6
All the above have a 5x114.3 bolt pattern, 67.1 center bore, and "high" offset, which is between +35 and +45
IIRC:
IIRC:
o rly?
o rly?
If the center bore information is correct, then apparently mazda changed center bore going from 4bolt to 5bolt wheels because I know for a fact the 4x100 miata wheels have too small a center bore to fit Nissan b13 sentra (that's what I was basing my personal experience on).. I was able to put 1998 200sx SE-R wheels on my Miata but not able to put Miata wheels on my 200sx because the center bore was too small.
the coupe wheels have a staggered width. 7.5" vs. 8" IIRC. my brother has them on his 5.5 gen with unidirectional treads, and hasn't rotated his tires once since he got them. the only way to do it is to break down all four tires and re-mount them. in other words, rotating JUST THE TIRES and not the wheels. it's even worse for wheels like the 300ZX T/T wheels, which are staggered AND unidirectional wheels. (R and L is embossed onto the wheel lol)
This is an old posting of mine. most ceners were larger than the maxima IIRC.
I was thinking OEM alloys from another car to replace my steelies. Made a list here.
Acura
3.0 CL V-6 98-on 5X114.3
LEGEND 91-on 15 X 6.5 5X114.3
NSX 91-on 15X6.5F/16X8R 5X114.3
RL 3.5 96-on 15 X 6.5 5X114.3
RSX 01-on 5X114.3
TL 3.5 96-on 15 X 6.5 5X114.3
TL 3.5 TYPE S 02- 17x6.5 5X114.3
MDX 01-on 17x7.5 5x114.3
Dodge
AVENGER 95-97 14 X 6 5X114.3
AVENGER 97- 16X7 5X114.3
AVENGER ES 97- 17X7 5X114.3
INTREPID 93-on 16 X 6 5X114.3
STEALTH 91-96 15 X 6 5X114.3
STEALTH ES,RT 91-95 16 X 8 5X114.3
STEALTH AWD, TURBO 91-96 17 X 8.5 5X114.3
STRATUS/ STRATUS RT 02-on 16X6 5X114.3
GRAND CARAVAN, CARAVAN LE 87-on 15 X 6 5X114.3
GRAND CARAVAN SPORT 97-98 16 X 7 5X114.3
GRAND CARAVAN SPORT 99-on 17 X 7.5 5X114.3
Ford
PROBE 93-96 16 X 7 5X114.3
PROBE GT 88-97 15 X 6 5X114.3
ESCAPE 01-on 15X 6 5X114.3
Honda
ACCORD (V-6) 98- 15X6 5X114.3
CIVIC SI HATCHBACK 02-on 16X7 5X114.3
PRELUDE, V-TECH 97-01 16X7 5X114.3
S2000 99-on 16X7 5X114.3
CR-V 97-on 15 X 6 5X114.3
ODYSSEY 95-on 15 X 6 5X114.3
Infinity
I30 95-97 15 X 6.5 5X114.3
J30 92-97 15 X 6 5X114.3
Q45 90-on 15 X 6 5X114.3
Isuzu
OASIS 97- 15X6 5X114.3
Lexus
ES 300 92-97 15 X 6 5X114.3
GS 300 93-on 16 X 7.5 5X114.3
GS 400 98 16X7.5 5X114.3
IS 300 2000-on 17 x 7 5X114.3
LS 400 90-94 16 X 7 5X114.3
SC 300 92-96 16 X 6.5 5X114.3
SC 400 91-on 16 X 7 5X114.3
SC 430 8 2002-on 18x8.5 5x114.3
Mazda
MILLENIA 94-on 15 X 6.5 5X114.3
MX-6 90-97 15 X 6 5X114.3
RX-7 93-96 16 X 8 5X114.3
RX7 GXL,GTU 86-92 15 X 7 5X114.3
RX7 TURBO II 87-92 16 X 7 5X114.3
626 88-on 15 X 6 5X114.3
929 88-on 15 X 6 5X114.3
MPV 99-on 15 X 6 5X114.3
MOUNTAINEER 93-on 15 X 6 5X114.3
DIAMANTE 91-96 15 X 6 5X114.3
ECLIPSE TURBO 89-97 16 X 6 5X114.3
GALANT 97-ON 15 X 6 5X114.3
STARION,TURBO 86-89 16 X 7,8 5X114.3
3000,GT,SL 91-96 16 X 8 5X114.3
3000 GT VR4 91-97 17 X 8.5 5X114.3
NISSAN
ALTIMA 02-on 15 X 6 5X114.3
240SX,SE 95-96 16 X 5.5 5X114.3
QUEST 93-on 15 X 6 5X114.3
Plymouth
LASER RS & RS TURBO,AWD 89-94 16 X 6 5X114.3
GRAND VOYAGER 88-on 15 X 6 5X114.3
Toyota
AVALON 95-97 15 X 6 5X114.3
CAMRY SOLARA 99-on 16 X 6 5X114.3
CRESSIDA 89-92 15 X 6 5X114.3
MR-2 92-95 15 X 7 5X114.3
SUPRA 93-96 16 X 8 5X114.3
SUPRA 93-96 17 X 8,F/ 17 X 9.5,R 5X114.3
SUPRA,TURBO 86-93 16 X 7 5X114.3
PREVIA 91-96 15 X 6 5X114.3
RAV4 96-97 16 X 7 5X114.3
RAV4 00-on 16 X 7 5X114.3
SIENNA 97- 15 X 6 5X114.3
Acura
RSX 01-on 5X114.3
Dodge
Ford
Honda
Infinity
Isuzu
Lexus
Mazda
NISSAN
Plymouth
Toyota
^^^sorry but IMO they dont look good on a 4th(or any maxima at that), no matter how you try it still looks like a "truck/suv" wheel on a maxima. i might as wheel convert my max to six lug and put titan wheels on my maxima.
^^^=1
^^^i think those are the only infinity/nissan wheels that look perfect on a 4th gen, both the base model 17s & the 18's...
^^^=1
I had a 93 MX-6 running 04 (I think) 18's. (edit) I meant Maxima wheels.
Bolted up fine on the front, needed wheel spacers on the back because the bore was different and the wheel wouldn't fit flush.
So from front to back was different for me, but I haven't tried Mazda to Nissan.
why you gotta 1up me?
mazda starion FTW!!! lol
Mazda
can someone help me.im new and cant post my own thread i got 18" 350z on my 98 max the rear rims are staged because my car is dropped 2.2 in the back. my rims hit the quarter panel at highspeeds. can i put the staged rims in the front will it effect my handling?
^^^ yes they do fit...
100% correct, I did try the same thing..
miata's rim don't fit on the 200sx at all.
To the guy with the red maxima with the Infiniti 18s what size tire are you running I got the 18" 350z wheels stagg and I'm going to do em black but not sure of wha tire to ae m planning on slammng the car on ksports
aminus21
Sep 12, 2015 04:53 PM
