HELP .... WIPERS DONT WORK, AND IT STARTED SNOWING !!!!
Old Dec 5, 2009 | 09:30 PM
scmaxima's Avatar
in my 96 gle, when you turn on the wipers they dont work, but if u silence everything else, u can hear like a motor is running, and especially when its on the highest speed u can hear the sound highly but nothing works.
you can manually control the blades like i did that before when it rained lightly, i would just get out the car and move the blades up and down.. i know this is not supposed to happen.
please tell me what do you guys think as it will be snowing a lot more soon.
from all i read it could either be the motor or the linkage ** ?
im not sure please share experience, i can get both of them for like 25$ each on ebay but i need to know what exactly is the bad part
THANKS for reading and answering
Old Dec 6, 2009 | 05:49 PM
RA030726's Avatar
I'm nutty for Nissans
You already answered your question. The motor makes noise, its working. You can move the wipers freely, that means they are disconnected from the motor.
Remove the wiper arms, pop off the cowl trim and see which connection failed. The linkage has metal arms with ball and socket pivots. The socket is plastic and wears out and falls off.
Old Dec 7, 2009 | 07:05 AM
Bassbreaker's Avatar
^ spot on. Exact same thing happened to me last winter. Had to drive to Nissan in a Snow storm with no wipers. The arm itself only cost $29. Only took about 15 mins to install it
Old Dec 7, 2009 | 07:14 AM
oVeRdOsE's Avatar
Or drill a hole and put a screw trough the ball pivot and the plastic cap.
i did this, and it still strong since 3 years now.
Old Dec 8, 2009 | 05:29 PM
Dlminny's Avatar
need new arms myself.
Old Dec 10, 2009 | 11:54 AM
96gxe5spd's Avatar
Had similar symptoms years ago, linkage was fine but the gearbox on the motor was shot. Spent maybe $15 bucks at a junkyard and no more problems. Might be worth checking out since its only held in place by 2 or 3 bolts.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
