no bounce on rear suspension
Old Dec 11, 2009 | 12:32 PM
hotimportnight9's Avatar
my rear suspension does not bounce it just hits the frame of the car, could it be my shocks bottoming out?
Old Dec 11, 2009 | 12:39 PM
sicivic89's Avatar
Is your car swagging in the rear? The car hits the frame when you are driving? Or while the car is parked and you push down on the rear of the car?
Old Dec 11, 2009 | 02:35 PM
pretty much when it hits little bumps it hits the frame driving and park, what you mean swagging?
Old Dec 11, 2009 | 02:41 PM
sicivic89's Avatar
I meant if you stand back from the car, does the rear look like it sit lower than the front? Sounds like your rear shocks are blown. Are the springs and shocks original factory stuff?
Old Dec 11, 2009 | 08:19 PM
yea i notice is lower and yes its all factory
Old Dec 11, 2009 | 09:12 PM
Snypa's Avatar
ur pretty much on springs alone right now.
Old Dec 11, 2009 | 11:11 PM
Mr.A32ftw's Avatar
factory meaning the same struts that came on the car 14 years ago?
Old Dec 11, 2009 | 11:58 PM
HandsonMaxima.'s Avatar
my struts were factory, lets just say there was BEYOND surface rust. so it happens
Old Dec 12, 2009 | 06:51 AM
yea something like that
Old Dec 12, 2009 | 08:35 AM
njmaxseltd's Avatar
The rear suspension can't hit the frame. There are bump stops incorporated into the rear shock assembly to restrict it's travel. With the factory ride height, there's plenty of room between the suspension and it's bump stop.
It soulds like you've got a harsh ride do to worn suspension components. Have a mechanic look at your vehicle if you're not handy. Otherwise, inspect it yourself and replace the worn components. Most likely it needs front struts and rear shocks.
Old Dec 12, 2009 | 12:55 PM
ok good then my frame cant get mest up, i was on the high way i manage to hit a bump with the left side and nothing happen but with the right side it hits hard so i guess its my shock i just order all 4 tokico illumina, if read correct i need the front mustang strut boot and the rears are miata boots correct ?
Old Dec 13, 2009 | 02:33 PM
jkahng's Avatar
someone correct me if i'm wrong... but, shocks absorb shocks. the weight of the car is held up by the springs.
if you have dead shocks, you'll have a very bouncy car over bumps.
your springs most likely lost their ability to hold the weight of the car and need replacing.
here's an example of bad shocks (before and after)
before
http://www.youtube.com/watch?v=MwBW15AO_Ag
after
http://www.youtube.com/watch?v=QjmkXfQSb-w
Old Dec 14, 2009 | 11:14 AM
before
after
the crazy things about it is that i notice it when its very cold like temps in the 30s but when it get warn 45 n up its fine, this is the second time it did that during a cold day
Old Dec 14, 2009 | 12:21 PM
MaxiNone's Avatar
most likely you need new rear struts. my car was doing the samething, got new struts and it fixed the problem...
Old Dec 14, 2009 | 04:06 PM
1992maximase30's Avatar
you want mine...the rear's bouces like a freakin buick.lol.
Old Dec 14, 2009 | 08:03 PM
aiight cool i just order my illuminas should get them sometime next week, does anyone know where i could get the rubber piece that goes on the spring i look at courtesynissan but damn their expensive, is there an alternative?
Old Dec 14, 2009 | 09:32 PM
internetautomar's Avatar
mod or sell?
that's because they are so far blown that there is water in there freezing!!
Old Dec 16, 2009 | 10:38 AM
[QUOTE=internetautomar;7337781]that's because they are so far blown that there is water in there freezing!![/QUOTE
damn i would never thought of that
Old Dec 16, 2009 | 10:45 AM
MaxiNone's Avatar
i would say junkyard. i think one of mine was busted so bad that i didnt use one on one of the rears. they're just bump stops, but deffinetly try the junkyard. i get bunch of small parts for free 99
Old Dec 16, 2009 | 10:56 AM
XeroX's Avatar
Hella internets
Wow...ive never lived in places that got that cold (im in sacramento) so excuse my naivity lol...but i would have never even guessed that...
is this a common issue with blown struts in colder places?
Old Dec 16, 2009 | 11:14 AM
mod or sell?
not that common, but when left blown long enough it does happen.
matts95max
Apr 23, 2025 10:44 AM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
A32goldylocks
Sep 2, 2015 06:39 AM
